Big block oil pump bolt torque? #2538924
08/20/18 11:21 AM
08/20/18 11:21 AM
gregsdart Offline OP
I am putting in a new five lobe Milodon pump body, which is aluminum, with an aluminum cover. I thought i read that is easy to over torque the bolts, and bind up or seize the pump? What should this combo be torqued to? Thanks in advance!!
Re: Big block oil pump bolt torque? [Re: gregsdart] #2538931
08/20/18 11:30 AM
08/20/18 11:30 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The spec is 30 ft lbs. but I have heard of people having binding problems on some pumps, so after you torque it down stick your priming rod in there and turn it over to make sure it feels fine.
2011 Drag Pak Challenger
Re: Big block oil pump bolt torque? [Re: gregsdart] #2538946
08/20/18 11:52 AM
08/20/18 11:52 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
And how comfortable are you with bolts that are little more than finger tight?!?!?
The problem is with the aluminum covers more than the pump body.
Re: Big block oil pump bolt torque? [Re: gregsdart] #2538995
08/20/18 01:15 PM
08/20/18 01:15 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If you really want to know where you are at, torque the pump down to 5 lbs, then put a dial or beam type torque wrench on the priming shaft and get a baseline, then torque down the pump and recheck the priming shaft.
Re: Big block oil pump bolt torque? [Re: gregsdart] #2539011
08/20/18 01:32 PM
08/20/18 01:32 PM
Call Tom at Milidon,805-577-5950, and ask them up
Re: Big block oil pump bolt torque? [Re: gregsdart] #2539278
08/20/18 09:50 PM
08/20/18 09:50 PM
Thanks, will call Tom. I have time anyway, the new pump body takes a longer distributor/oilpump drive shaft. Its on the way, hope to run on Saturday, provided i figure out why #3 isn't firing!
Re: Big block oil pump bolt torque? [Re: gregsdart] #2539391
08/21/18 01:23 AM
08/21/18 01:23 AM
Have the intergear in before you torque em
Re: Big block oil pump bolt torque? [Re: gregsdart] #2539412
08/21/18 02:41 AM
08/21/18 02:41 AM
AndyF Offline
AndyF  Offline
The important thing is to check for any binding after you've torqued the pump down. Some people forget to do this and the pump can eat itself when the engine is fired.
