Big block oil pump bolt torque?
#2538924
08/20/18 11:21 AM
08/20/18 11:21 AM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am putting in a new five lobe Milodon pump body, which is aluminum, with an aluminum cover. I thought i read that is easy to over torque the bolts, and bind up or seize the pump? What should this combo be torqued to? Thanks in advance!!
Re: Big block oil pump bolt torque?
[Re: gregsdart]
#2538931
08/20/18 11:30 AM
08/20/18 11:30 AM
Posts: 2,632 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The spec is 30 ft lbs. but I have heard of people having binding problems on some pumps, so after you torque it down stick your priming rod in there and turn it over to make sure it feels fine.
2011 Drag Pak Challenger
[Re: gregsdart]
#2538995
08/20/18 01:15 PM
08/20/18 01:15 PM
rickseeman
Stuttgart, Arkansas
If you really want to know where you are at, torque the pump down to 5 lbs, then put a dial or beam type torque wrench on the priming shaft and get a baseline, then torque down the pump and recheck the priming shaft.
[Re: gregsdart]
#2539278
08/20/18 09:50 PM
08/20/18 09:50 PM
gregsdart
Thanks, will call Tom. I have time anyway, the new pump body takes a longer distributor/oilpump drive shaft. Its on the way, hope to run on Saturday, provided i figure out why #3 isn't firing!
[Re: gregsdart]
#2539391
08/21/18 01:23 AM
08/21/18 01:23 AM
RapidRobert
Have the intergear in before you torque em
