Anodizing valve covers #2538727
08/19/18 10:30 PM
08/19/18 10:30 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Any reason the mopar black wrinkle small block valve covers couldnt be sandblasted and anodized red. Would that procedure work on the “ fins” part of them?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Anodizing valve covers [Re: B3422W5] #2538737
08/19/18 10:53 PM
08/19/18 10:53 PM
Kirkland, Washington
Pacnorthcuda Offline
No and yes to your questions. Be careful on the blast media for AL though. Lotta people use walnut shells.
Re: Anodizing valve covers [Re: B3422W5] #2538751
08/19/18 11:21 PM
08/19/18 11:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would highly suggest you ask whomever you are going to have anodize them. I'd let them do it all otherwise any issues will be do to someone else.
Don't be the exception.
Re: Anodizing valve covers [Re: B3422W5] #2538752
08/19/18 11:31 PM
08/19/18 11:31 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Can anybody recommend a good anodizer to do some stainless moldings?
Re: Anodizing valve covers [Re: Supercuda] #2538754
08/19/18 11:34 PM
08/19/18 11:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'd try paint stripper before any sort of media blasting. As mentioned ask the anodizing guys on what the surface needs to be and how to get there, or just let them do if it's more involved than any of us know.
Anodizing will cover the whole part as the part is submerged. If you want the fins to be aluminum you can block sand them afterwards.
I'd like to do something like this jet fuel finish to a set of valve covers someday. It changes color depending on where your standing.
Re: Anodizing valve covers [Re: AeroMonte] #2538902
08/20/18 10:33 AM
08/20/18 10:33 AM
E
earlymopar Offline
earlymopar  Offline
E
Anodization is done on aluminum parts not stainless.
- EM
Re: Anodizing valve covers [Re: earlymopar] #2539006
08/20/18 01:28 PM
08/20/18 01:28 PM
- EM
That be true up scope
There is hard and regular anodizing also, hard is for wear protection and regular is for corrosion prevention scope
Re: Anodizing valve covers [Re: B3422W5] #2539131
08/20/18 04:51 PM
08/20/18 04:51 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Chromate conversion in clear can be done on stainless steel.
Check with your anodizing shop on what process they offer and what materials they can be done on. Type 2 can be done in colors. Type 3 is the dark grey, hardcoat that is most commonly seen on cookware. Chromate conversions in clear or yellow can be done on steel varieties, and of course there is copper, nickle, and chrome plating processes.
