Anodizing valve covers
#2538727
08/19/18 10:30 PM
08/19/18 10:30 PM
Posts: 11,705 Portage,michigan
B3422W5
Portage,michigan
Any reason the mopar black wrinkle small block valve covers couldnt be sandblasted and anodized red. Would that procedure work on the “ fins” part of them?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Anodizing valve covers
[Re: B3422W5]
#2538751
08/19/18 11:21 PM
08/19/18 11:21 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I would highly suggest you ask whomever you are going to have anodize them. I'd let them do it all otherwise any issues will be do to someone else.
[Re: Supercuda]
#2538754
08/19/18 11:34 PM
08/19/18 11:34 PM
Posts: 20,462 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I'd try paint stripper before any sort of media blasting. As mentioned ask the anodizing guys on what the surface needs to be and how to get there, or just let them do if it's more involved than any of us know. Anodizing will cover the whole part as the part is submerged. If you want the fins to be aluminum you can block sand them afterwards. I'd like to do something like this jet fuel finish to a set of valve covers someday. It changes color depending on where your standing.
[Re: earlymopar]
#2539006
08/20/18 01:28 PM
08/20/18 01:28 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Anodization is done on aluminum parts not stainless.
- EM That be true There is hard and regular anodizing also, hard is for wear protection and regular is for corrosion prevention
