I had my 727 Rebuilt, Now my Speedometer is not working! #2533682
08/09/18 12:05 PM
08/09/18 12:05 PM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
I just had my 727 rebuilt. The speedometer was working prior to the rebuild. Now, after picking up the car the speedometer is dead.
I only looked to see if the cable was hooked up (and it is). Where should I start de-bugging the problem? Could the gear be disengaged/worn and not making contact after the rebuild?
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: RobG] #2533687
08/09/18 12:19 PM
08/09/18 12:19 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
The housing that the speedo gear is installed into needs to be clocked correctly for the diameter of the gear you're running. If you know the tooth count of the gear you'll see the hash marks on the housing to see how far to move it clockwise.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: MarkZ] #2533694
08/09/18 12:30 PM
08/09/18 12:30 PM
pull the cable & check that the inner cable is seated all the way forward (toward the speedo) in the sheath. If good there you'd need to pull the adapter & see what is up in there (& first as said check the clocking). Jack the car up as high as you can on the dr side to minimize fluid loss
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: RobG] #2533796
08/09/18 03:08 PM
08/09/18 03:08 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If the rebuilder couldn't even clock the pinion adapter correctly, I'd wonder what else he screwed up.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: RobG] #2533801
08/09/18 03:20 PM
08/09/18 03:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: John_Kunkel] #2533960
08/09/18 10:00 PM
08/09/18 10:00 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes that's a concern
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: Morty426] #2534139
08/10/18 12:45 PM
08/10/18 12:45 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
check to see if you pulled the cable out of the speedo
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: John_Kunkel] #2534148
08/10/18 12:55 PM
08/10/18 12:55 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
haha yep, nothing on the inside is as simple as this.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: GomangoCuda] #2534172
08/10/18 01:37 PM
08/10/18 01:37 PM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Why not take it back to rebuilder.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: RobG] #2534194
08/10/18 02:32 PM
08/10/18 02:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you disconnected the cable to see if he put the gear in the trans?
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: stumpy] #2534388
08/10/18 09:54 PM
08/10/18 09:54 PM
Rob when the time comes, for sure post what it ends up being.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: John_Kunkel] #2534454
08/11/18 02:27 AM
08/11/18 02:27 AM
Guitar Jones Offline
A lot of these places have kids or limited experience guys doing the R&R work for the transmission builders.
And yeah the speedo pinion is clocked wrong.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: stumpy] #2534695
08/11/18 06:12 PM
08/11/18 06:12 PM
Rio Linda, CA
Rio Linda, CA
If the pinion was missing, there would be noticeable fluid leakage from the hole. A small common screwdriver can be used in the square opening in the pinion shaft to turn the shaft. If it will spin, the pinion isn't making contact with the drive gear.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: John_Kunkel] #2535026
08/12/18 12:03 PM
08/12/18 12:03 PM
moparx Offline
moparx  Offline
i always use the small screwdriver trick john mentioned above to make sure the pinion is meshing correctly with the output shaft gear before tightening down the retainer fork bolt.
beer
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: RapidRobert] #2535584
08/13/18 12:51 PM
08/13/18 12:51 PM
Addison Twp, Mi.
RobG Offline OP
RobG  Offline OP
Addison Twp, Mi.
I finally had time to work on the car Sunday. It was clocked incorrectly.
I do have another issue showing up - the needle is jumping at lower speeds. I guess I will start by greasing the cable to see if this eliminates the issue.
Re: I had my 727 Rebuilt, Now my Speedometer is not working! [Re: RobG] #2535591
08/13/18 12:59 PM
08/13/18 12:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Use speedometer lube not any old grease.
Don't be the exception.
