I had my 727 Rebuilt, Now my Speedometer is not working!
#2533682
08/09/18 12:05 PM
08/09/18 12:05 PM
Posts: 2,332 Addison Twp, Mi.
RobG
Addison Twp, Mi.
I just had my 727 rebuilt. The speedometer was working prior to the rebuild. Now, after picking up the car the speedometer is dead.
I only looked to see if the cable was hooked up (and it is). Where should I start de-bugging the problem? Could the gear be disengaged/worn and not making contact after the rebuild?
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: I had my 727 Rebuilt, Now my Speedometer is not working!
[Re: RobG]
#2533687
08/09/18 12:19 PM
08/09/18 12:19 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
The housing that the speedo gear is installed into needs to be clocked correctly for the diameter of the gear you're running. If you know the tooth count of the gear you'll see the hash marks on the housing to see how far to move it clockwise.
[Re: MarkZ]
#2533694
08/09/18 12:30 PM
08/09/18 12:30 PM
RapidRobert
pull the cable & check that the inner cable is seated all the way forward (toward the speedo) in the sheath. If good there you'd need to pull the adapter & see what is up in there (& first as said check the clocking). Jack the car up as high as you can on the dr side to minimize fluid loss
[Re: RobG]
#2533796
08/09/18 03:08 PM
08/09/18 03:08 PM
Posts: 25,822 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the rebuilder couldn't even clock the pinion adapter correctly, I'd wonder what else he screwed up.
[Re: John_Kunkel]
#2533960
08/09/18 10:00 PM
08/09/18 10:00 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
If the rebuilder couldn't even clock the pinion adapter correctly, I'd wonder what else he screwed up. Yes that's a concern
[Re: John_Kunkel]
#2534148
08/10/18 12:55 PM
08/10/18 12:55 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
If the rebuilder couldn't even clock the pinion adapter correctly, I'd wonder what else he screwed up. yep, nothing on the inside is as simple as this.
[Re: stumpy]
#2534388
08/10/18 09:54 PM
08/10/18 09:54 PM
RapidRobert
Rob when the time comes, for sure post what it ends up being.
[Re: John_Kunkel]
#2534454
08/11/18 02:27 AM
08/11/18 02:27 AM
Guitar Jones
If the rebuilder couldn't even clock the pinion adapter correctly, I'd wonder what else he screwed up. A lot of these places have kids or limited experience guys doing the R&R work for the transmission builders. And yeah the speedo pinion is clocked wrong.
[Re: stumpy]
#2534695
08/11/18 06:12 PM
08/11/18 06:12 PM
John_Kunkel
Rio Linda, CA
Have you disconnected the cable to see if he put the gear in the trans? If the pinion was missing, there would be noticeable fluid leakage from the hole. A small common screwdriver can be used in the square opening in the pinion shaft to turn the shaft. If it will spin, the pinion isn't making contact with the drive gear.
[Re: RapidRobert]
#2535584
08/13/18 12:51 PM
08/13/18 12:51 PM
RobG
Addison Twp, Mi.
Rob when the time comes, for sure post what it ends up being. I finally had time to work on the car Sunday. It was clocked incorrectly. I do have another issue showing up - the needle is jumping at lower speeds. I guess I will start by greasing the cable to see if this eliminates the issue.
[Re: RobG]
#2535591
08/13/18 12:59 PM
08/13/18 12:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Use speedometer lube not any old grease.
