Boogered up LA valve cover bolt hole - Suggestions? #2525144
07/22/18 12:00 AM
07/22/18 12:00 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have these J-heads that I'd like to clean up and get ready to put to use and there's this lovely valve cover bolt hole in it.
As you can see, it's pretty rough, but it is just a valve cover bolt, so the required torque is very low. I plan on using studs in the valve cover holes to help keep from working this one much in the future.
What do you think?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525153
07/22/18 12:22 AM
07/22/18 12:22 AM
Andrewh Offline
Andrewh  Offline
I don't know if this would work. I would probably oil up a stud or bolt and then put jb weld all over it and insert it and mash it down till it was stuck in as far as I wanted it to go. clean up any extra around the hole to minimize how much I would have to file off later once it hardened.
if the oil works as it should you could then pull the bolt out and have it already threaded for you.
I might even cut a small lip inside for something the jb weld could hold on to better.
but since you know feets, I might see if he could cut it nicely and press a plug in and cut new threads.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525160
07/22/18 12:46 AM
07/22/18 12:46 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They make something like that called form a thread, but I'd look at a helicoil.
Don't be the exception.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525178
07/22/18 01:22 AM
07/22/18 01:22 AM
What do you think?
I'd clean it & JBweld in a stud
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525180
07/22/18 01:22 AM
07/22/18 01:22 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Looks a little big for a helicoil. Probably needs an insert. But I would not do that by hand. Should be done on a mill or at least bolted down on a good drill press. A drill will wander - need to clean up with an end mill in my opinion.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: markz528] #2525183
07/22/18 01:28 AM
07/22/18 01:28 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
weld it up,drill it and tap it?
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525186
07/22/18 01:33 AM
07/22/18 01:33 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
end mill and helicoil
or stud that is larger on one end to thread into over size thread in head
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525203
07/22/18 02:13 AM
07/22/18 02:13 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
drill and tap for a relatively large bolt (3/8, 7/16), cutoff wheel and smooth off excess bolt , and then drill and tap stock size. Did it once on a rearend yoke on a truck, and got away with it. No problem on a low tension valve cover bolt.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: bbtrux] #2525240
07/22/18 09:51 AM
07/22/18 09:51 AM
Guitar Jones Offline
I've done this on a rocker shafts hold down bolt with no problems and I did it by hand.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: bbtrux] #2525250
07/22/18 10:18 AM
07/22/18 10:18 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I went this route this morning but went ahead and tapped the new bigger bolt first. 3/8" bolt is jb welded into the new threads, I think it'll hold pretty well for what it needs to do.
Thanks all. up
2020 RAM 1500
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: bbtrux] #2525309
07/22/18 01:06 PM
07/22/18 01:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Genius, I have never even thought of that. I will have to remember it.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: Supercuda] #2525325
07/22/18 01:38 PM
07/22/18 01:38 PM
Me too!
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525338
07/22/18 02:19 PM
07/22/18 02:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I got a set of J heads where one of the exhaust hole holes is similarly messed up, this will fix it
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525433
07/22/18 05:17 PM
07/22/18 05:17 PM
BDW Offline
BDW  Offline
So your drilling the stud? What keeps that in place and not spinning?
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: BDW] #2525444
07/22/18 05:39 PM
07/22/18 05:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Missed this did you?
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: GoodysGotaCuda] #2525446
07/22/18 05:47 PM
07/22/18 05:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This works for antique furniture with worn out holes for caster wheels too.
Over drill the hole, apply glue to a dowel of the same species, tap in, trim flat.
When the glue is try you can re-drill the correct size hole for the caster wheel.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: BDW] #2526525
07/24/18 06:26 PM
07/24/18 06:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It should stay in place because the drill bit is spinning the same direction the bolt was threaded in. Same rule applies when tapping the new hole .
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: Alaskan_TA] #2526541
07/24/18 06:51 PM
07/24/18 06:51 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i've also done the exact same process with a hardwood dowel rod in the maple neck on my bass guitar...40yrs of people pulling the neck off for various reasons..
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: krautrock] #2526552
07/24/18 07:03 PM
07/24/18 07:03 PM
Wood glue and tooth picks work for that and it's a lot easier.
Re: Boogered up LA valve cover bolt hole - Suggestions? [Re: Guitar Jones] #2526557
07/24/18 07:13 PM
07/24/18 07:13 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i did that once or twice and it didn't last, ended up just doing it better to be done with it. a maple dowel and then redrill the hole and bolt the neck back on nice and tight.
