Re: Boogered up LA valve cover bolt hole - Suggestions?
[Re: GoodysGotaCuda]
#2525160
07/22/18 12:46 AM
07/22/18 12:46 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They make something like that called form a thread, but I'd look at a helicoil.
#2525178
07/22/18 01:22 AM
07/22/18 01:22 AM
RapidRobert
I'd clean it & JBweld in a stud
#2525180
07/22/18 01:22 AM
07/22/18 01:22 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Looks a little big for a helicoil. Probably needs an insert. But I would not do that by hand. Should be done on a mill or at least bolted down on a good drill press. A drill will wander - need to clean up with an end mill in my opinion.
[Re: bbtrux]
#2525240
07/22/18 09:51 AM
07/22/18 09:51 AM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
drill and tap for a relatively large bolt (3/8, 7/16), cutoff wheel and smooth off excess bolt , and then drill and tap stock size. Did it once on a rearend yoke on a truck, and got away with it. No problem on a low tension valve cover bolt. I've done this on a rocker shafts hold down bolt with no problems and I did it by hand.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: bbtrux]
#2525250
07/22/18 10:18 AM
07/22/18 10:18 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
drill and tap for a relatively large bolt (3/8, 7/16), cutoff wheel and smooth off excess bolt , and then drill and tap stock size. Did it once on a rearend yoke on a truck, and got away with it. No problem on a low tension valve cover bolt. I went this route this morning but went ahead and tapped the new bigger bolt first. 3/8" bolt is jb welded into the new threads, I think it'll hold pretty well for what it needs to do. Thanks all.
[Re: bbtrux]
#2525309
07/22/18 01:06 PM
07/22/18 01:06 PM
Supercuda
About to go away
About to go away
up yours
drill and tap for a relatively large bolt (3/8, 7/16), cutoff wheel and smooth off excess bolt , and then drill and tap stock size. Did it once on a rearend yoke on a truck, and got away with it. No problem on a low tension valve cover bolt. Genius, I have never even thought of that. I will have to remember it.
#2525338
07/22/18 02:19 PM
07/22/18 02:19 PM
Supercuda
About to go away
About to go away
up yours
I got a set of J heads where one of the exhaust hole holes is similarly messed up, this will fix it
[Re: BDW]
#2525444
07/22/18 05:39 PM
07/22/18 05:39 PM
Supercuda
About to go away
About to go away
up yours
So your drilling the stud? What keeps that in place and not spinning? Missed this did you? 3/8" bolt is jb welded into the new threads
[Re: BDW]
#2526525
07/24/18 06:26 PM
07/24/18 06:26 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
So your drilling the stud? What keeps that in place and not spinning? It should stay in place because the drill bit is spinning the same direction the bolt was threaded in. Same rule applies when tapping the new hole .
[Re: Alaskan_TA]
#2526541
07/24/18 06:51 PM
07/24/18 06:51 PM
Posts: 2,094 central texas
krautrock
central texas
This works for antique furniture with worn out holes for caster wheels too.
Over drill the hole, apply glue to a dowel of the same species, tap in, trim flat.
When the glue is try you can re-drill the correct size hole for the caster wheel. i've also done the exact same process with a hardwood dowel rod in the maple neck on my bass guitar...40yrs of people pulling the neck off for various reasons..
[Re: krautrock]
#2526552
07/24/18 07:03 PM
07/24/18 07:03 PM
Guitar Jones
When the glue is try you can re-drill the correct size hole for the caster wheel. i've also done the exact same process with a hardwood dowel rod in the maple neck on my bass guitar...40yrs of people pulling the neck off for various reasons.. Wood glue and tooth picks work for that and it's a lot easier.
[Re: Guitar Jones]
#2526557
07/24/18 07:13 PM
07/24/18 07:13 PM
krautrock
central texas
When the glue is try you can re-drill the correct size hole for the caster wheel. i've also done the exact same process with a hardwood dowel rod in the maple neck on my bass guitar...40yrs of people pulling the neck off for various reasons.. Wood glue and tooth picks work for that and it's a lot easier. i did that once or twice and it didn't last, ended up just doing it better to be done with it. a maple dowel and then redrill the hole and bolt the neck back on nice and tight.
