Drag Week 2018 mods wrapping up(hopefully) #2521729
07/14/18 08:55 AM
07/14/18 08:55 AM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
I got my car freed from Jackstand prison last weekend.
I have made some changes to help my average time on Drag week so I can qualify for the quick 32 bracket race for the Street machine class. Despite going faster I have slid down the qualifying ladder to an uncomfortable point the last two years I ran.
Since my 2016 average of 11.15 the car has run a 10.71 in decent air.
I had just finished up a few changes when i took the video below this post. I would love to have this thing run 10.50s in decent air.
W2 EFI Tunnel Ram(was on the car for the 10.71)
8.75 to Dana 60 swap(4.10 gear)
Wilwood rear discs
changed from a 727 to a 904 i borrowed from my Dad, I have a low gear 904 to build if we think it needs it.
went from a 4500 converter to a 4800
took the stock hood off after I added the tunnel ram.
It is the heaviest A body Barracuda around at 3600LBS with a 240Lb driver. I know the dana is heavier but I hope there is at least a little weight savings by going to the 904 and glass hood, as well as losing the drum brakes.
Here is a short video I took in the driveway after getting it out of the garage after a few months.
https://youtu.be/FEvTC9HFE0I
68 Barracuda Formula S 340
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2521730
07/14/18 09:15 AM
07/14/18 09:15 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looking good! A little early to ready to go though isn't it?
69 GTX 68 Road Runner
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: JERICOGTX] #2521732
07/14/18 09:22 AM
07/14/18 09:22 AM
Tulsa OK
Tulsa OK
It feels like it, but it gives me time if none of this works out lol.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2521747
07/14/18 11:08 AM
07/14/18 11:08 AM
Canada north shore lake Ontari...
ross Offline
ross  Offline
looks good Clark. I was surprised at the weight. Almost as much as my car. good luck.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2521760
07/14/18 11:50 AM
07/14/18 11:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Just did the 904 swap myself..... 46lb difference including respective converters. My S60 weighed 187lb including hats and rotors. Also dropped a couple with the aluminum driveshaft and cutting down numerous suspension bolts.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2521792
07/14/18 01:12 PM
07/14/18 01:12 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Looks and sounds great!! What does it run in our normal mid-summer oppressive temperature and humidity? 10.90's? Should be plenty quick enough to keep you in the 32 car field!
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2521793
07/14/18 01:14 PM
07/14/18 01:14 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Adding flash/stall and moving weight to the rear should help your short times, would be my guess.
Nice looking fastback. I have always liked 67-69 fastback Cudas but for some reason I keep buying Darts
"Just a Bracket car dressed up like a streetcar"
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2521849
07/14/18 03:39 PM
07/14/18 03:39 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
LOoking good, nice improvement. Hopefully that gives you a comfortable position in the quick 32. But we probably aren't going to have good air this year, we are going to have hot, southern air. The power adder cars have an advantage there. Is that 3600# with the lighter trans and brakes? If so, that's B body weight, your car needs an appointment with Jenny Craig. stirthepot sawzall laugh2
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522079
07/15/18 11:47 AM
07/15/18 11:47 AM
Tulsa OK
Tulsa OK
Joel that is pre modification weight, so hopefully I come out less than I started with, i lost a little bit of weight myself.
Blusmbl, It is usually down a .1 or .2 in the summer heat but that was when it had the stock hood and was getting 150* air into the throttle body at the start of the run.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522084
07/15/18 11:57 AM
07/15/18 11:57 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Man some of you guys have the fattest A body’s I have ever seen. Take your thump off the scale.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522106
07/15/18 01:15 PM
07/15/18 01:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That is such a cool car. I'm sure you will meet your goals.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522260
07/15/18 08:07 PM
07/15/18 08:07 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Looks and sounds nice!
Hope everything goes according to plan!
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: pittsburghracer] #2522491
07/16/18 11:55 AM
07/16/18 11:55 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By pittsburghracer
Man some of you guys have the fattest A body’s I have ever seen. Take your thumb off the scale.
John,
Same week, three days, three different tracks on Drag Week. All steel, Formula S, stock seats, stock fuel tank, R1/W2 engine, full cage, front discs and lighter than stock wheels. 6'3"+ driver 3,600 lbs.
That is what it is. Sorry if you think we are lying.
Bill
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522497
07/16/18 12:02 PM
07/16/18 12:02 PM
an8sec70cuda Offline
What? A drag week car that hasn't been in pieces all year and then getting final assembly in the tech line? LOL, good luck this year! I'm gonna try to get out there to watch at Darlington.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: an8sec70cuda] #2522502
07/16/18 12:13 PM
07/16/18 12:13 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Unicorns do exist.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522560
07/16/18 02:15 PM
07/16/18 02:15 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Good luck on the trip Clark !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522575
07/16/18 02:34 PM
07/16/18 02:34 PM
PA.
"Little"John
"Little"John
PA.
Goodluck and the way the weather has been this year I hope you guys have air conditioning to ease the trip some. A friend of mine won last year in his nitrous mustang and then sold it to another friend. He is going to go turbo power now.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522587
07/16/18 02:45 PM
07/16/18 02:45 PM
Tulsa OK
Tulsa OK
Yeah it is going to be a hot one I am sure. The worse yet was 2013 for me, I normally like to hang my hand on the cage going down the road. There was one day in 2013 where the cage was too hot to leave my hand on.
Chip it is ready to make passes but I haven't fit the new hood yet or found new rear wheels for street tires, or put a trans blanket on yet. I don't plan on working on it in the tech line but crap happens lol. If you make it to Darlington be sure to find me and say hello.
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522645
07/16/18 04:32 PM
07/16/18 04:32 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
How much fuel do you run in it? I installled the holley hydra mat. I used to have to run mine with about 5/8th’s of a tank or it would uncover the pick up. Now I can run it with 3 gallons. A little over 100lbs of fuel weight out of the car. Mine was stock tank 3/8 pick up.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Drag Week 2018 mods wrapping up(hopefully) [Re: Bad340fish] #2522659
07/16/18 04:48 PM
07/16/18 04:48 PM
Tulsa OK
Tulsa OK
I have a sump system a friend of mine and I designed and welded in the stock tank. We didn't quite get it at the angle it needs to be at so it needs some improvement but it works. I can run it pretty low and not have any trouble. That being said if I go bracket race I fill it all the way up to alleviate any worries about fuel. The only time I have noticed a problem was under heavy braking and low fuel levels, no pressure loss but I could here the pumps rev up some.
