Drag Week 2018 mods wrapping up(hopefully)
#2521729
07/14/18 08:55 AM
07/14/18 08:55 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I got my car freed from Jackstand prison last weekend. I have made some changes to help my average time on Drag week so I can qualify for the quick 32 bracket race for the Street machine class. Despite going faster I have slid down the qualifying ladder to an uncomfortable point the last two years I ran. Since my 2016 average of 11.15 the car has run a 10.71 in decent air. I had just finished up a few changes when i took the video below this post. I would love to have this thing run 10.50s in decent air. W2 EFI Tunnel Ram(was on the car for the 10.71) 8.75 to Dana 60 swap(4.10 gear) Wilwood rear discs changed from a 727 to a 904 i borrowed from my Dad, I have a low gear 904 to build if we think it needs it. went from a 4500 converter to a 4800 took the stock hood off after I added the tunnel ram. It is the heaviest A body Barracuda around at 3600LBS with a 240Lb driver. I know the dana is heavier but I hope there is at least a little weight savings by going to the 904 and glass hood, as well as losing the drum brakes. Here is a short video I took in the driveway after getting it out of the garage after a few months. https://youtu.be/FEvTC9HFE0I
68 Barracuda Formula S 340
Re: Drag Week 2018 mods wrapping up(hopefully)
[Re: Bad340fish]
#2521730
07/14/18 09:15 AM
07/14/18 09:15 AM
Posts: 10,032 MN
JERICOGTX
MN
Looking good! A little early to ready to go though isn't it?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2521732
07/14/18 09:22 AM
07/14/18 09:22 AM
Bad340fish
Tulsa OK
Looking good! A little early to ready to go though isn't it? It feels like it, but it gives me time if none of this works out lol.
[Re: Bad340fish]
#2521760
07/14/18 11:50 AM
07/14/18 11:50 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Just did the 904 swap myself..... 46lb difference including respective converters. My S60 weighed 187lb including hats and rotors. Also dropped a couple with the aluminum driveshaft and cutting down numerous suspension bolts.
[Re: Bad340fish]
#2521792
07/14/18 01:12 PM
07/14/18 01:12 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Looks and sounds great!! What does it run in our normal mid-summer oppressive temperature and humidity? 10.90's? Should be plenty quick enough to keep you in the 32 car field!
[Re: Bad340fish]
#2521793
07/14/18 01:14 PM
07/14/18 01:14 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Adding flash/stall and moving weight to the rear should help your short times, would be my guess.
Nice looking fastback. I have always liked 67-69 fastback Cudas but for some reason I keep buying Darts
"Just a Bracket car dressed up like a streetcar"
[Re: Bad340fish]
#2521849
07/14/18 03:39 PM
07/14/18 03:39 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Bad340fish]
#2522079
07/15/18 11:47 AM
07/15/18 11:47 AM
Bad340fish
Tulsa OK
Joel that is pre modification weight, so hopefully I come out less than I started with, i lost a little bit of weight myself.
Blusmbl, It is usually down a .1 or .2 in the summer heat but that was when it had the stock hood and was getting 150* air into the throttle body at the start of the run.
[Re: Bad340fish]
#2522084
07/15/18 11:57 AM
07/15/18 11:57 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man some of you guys have the fattest A body’s I have ever seen. Take your thump off the scale.
[Re: Bad340fish]
#2522106
07/15/18 01:15 PM
07/15/18 01:15 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That is such a cool car. I'm sure you will meet your goals.
[Re: pittsburghracer]
#2522491
07/16/18 11:55 AM
07/16/18 11:55 AM
Posts: 3,518 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Man some of you guys have the fattest A body’s I have ever seen. Take your thumb off the scale. John, Same week, three days, three different tracks on Drag Week. All steel, Formula S, stock seats, stock fuel tank, R1/W2 engine, full cage, front discs and lighter than stock wheels. 6'3"+ driver 3,600 lbs. That is what it is. Sorry if you think we are lying. Bill
[Re: Bad340fish]
#2522497
07/16/18 12:02 PM
07/16/18 12:02 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
What? A drag week car that hasn't been in pieces all year and then getting final assembly in the tech line? LOL, good luck this year! I'm gonna try to get out there to watch at Darlington.
[Re: an8sec70cuda]
#2522502
07/16/18 12:13 PM
07/16/18 12:13 PM
Posts: 10,032 MN
JERICOGTX
MN
What? A drag week car that hasn't been in pieces all year and then getting final assembly in the tech line? Unicorns do exist.
69 GTX
68 Road Runner
[Re: Bad340fish]
#2522560
07/16/18 02:15 PM
07/16/18 02:15 PM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Good luck on the trip Clark !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Bad340fish]
#2522575
07/16/18 02:34 PM
07/16/18 02:34 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Goodluck and the way the weather has been this year I hope you guys have air conditioning to ease the trip some. A friend of mine won last year in his nitrous mustang and then sold it to another friend. He is going to go turbo power now.
[Re: Bad340fish]
#2522587
07/16/18 02:45 PM
07/16/18 02:45 PM
Bad340fish
Tulsa OK
Yeah it is going to be a hot one I am sure. The worse yet was 2013 for me, I normally like to hang my hand on the cage going down the road. There was one day in 2013 where the cage was too hot to leave my hand on.
Chip it is ready to make passes but I haven't fit the new hood yet or found new rear wheels for street tires, or put a trans blanket on yet. I don't plan on working on it in the tech line but crap happens lol. If you make it to Darlington be sure to find me and say hello.
[Re: Bad340fish]
#2522659
07/16/18 04:48 PM
07/16/18 04:48 PM
Bad340fish
Tulsa OK
I have a sump system a friend of mine and I designed and welded in the stock tank. We didn't quite get it at the angle it needs to be at so it needs some improvement but it works. I can run it pretty low and not have any trouble. That being said if I go bracket race I fill it all the way up to alleviate any worries about fuel. The only time I have noticed a problem was under heavy braking and low fuel levels, no pressure loss but I could here the pumps rev up some.
