trans slipping, Go back w/727 or glide? #252160
03/12/09 11:32 PM
03/12/09 11:32 PM
southwest Alabama
challenger73400 Offline OP
southwest Alabama
Well, after a few runs with the new motor the trans started sliding on the 2-3 shift. I made it to the finals Sat nite (finished runner up) but the motor flared on the 2-3 shift. Since putting the new motor in it the 2-3 shift has been a bit soft.
Anyway, now I gotta build a trans. I'm running a 470 w/stealth heads and turning 6.06 on a 600' track.(about 10.20 in the full 1/4)2800# Dakota
I have a spare 727 out of a motorhome that should have the 5 disk clutch in it. Should I put a 727 together with a few good parts or go with a glide, witch means modifiy cross member, new drive shaft, adapter kit, shifter, converter?
P.S. I had a 1.341 60ft Sat nite so its leaving hard for my et.
Re: trans slipping, Go back w/727 or glide? [Re: challenger73400] #252161
03/12/09 11:39 PM
03/12/09 11:39 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Personally, I would stay W/ the 727. Probably cheaper and with less down time.
Re: trans slipping, Go back w/727 or glide? [Re: challenger73400] #252162
03/12/09 11:39 PM
03/12/09 11:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Would be alot cheaper to just rebuild what you have
(or the other 727) you would most likely loose some on
your 60' if you changed over to the glide... unless
you have a wheel stand problem
Re: trans slipping, Go back w/727 or glide? [Re: MR_P_BODY] #252163
03/12/09 11:41 PM
03/12/09 11:41 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
I'm sure you know this, but give the converter a good flush before you put it back in your rebuilt 727
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Post deleted by Defbob [Re: challenger73400] #252164
03/12/09 11:42 PM
03/12/09 11:42 PM
Re: trans slipping, Go back w/727 or glide? #252165
03/12/09 11:51 PM
03/12/09 11:51 PM
southwest Alabama
southwest Alabama
Thanks guys. Thats what I wanted to do but all my Chevy racing buddys about had me brain washed into putting a glide in it.
727 it is!
Re: trans slipping, Go back w/727 or glide? [Re: challenger73400] #252166
03/12/09 11:57 PM
03/12/09 11:57 PM
PA
moparacer Offline
moparacer  Offline
PA
I would build a glide....As a matter of fact I just built one for my BB Dart project........
I had a 88 Dakota 360 CID Alky small block that ran 9.77 best and without a doubt the powerglide swap was the best thing I ever did to it......
I have that same glide thats 10 years old fresh and ready to go behind my 7.50 dragster when Ryan gets the engine finished for it.....
No way can anyone on here tell me a 727 is any stronger then a glide if both are done properly......
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: trans slipping, Go back w/727 or glide? [Re: challenger73400] #252167
03/13/09 12:11 AM
03/13/09 12:11 AM
jax. fla.
70Dustmite440 Offline
jax. fla.
If your running a turbo action v/b change it. The griner flows more fluid to the high gear clutches. I was burning up high gear until i was told about this fix, no more problems for me.
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: trans slipping, Go back w/727 or glide? [Re: 70Dustmite440] #252168
03/13/09 12:18 AM
03/13/09 12:18 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
727 all the way, A & A parts best there is, look me up i build alot and know some cool tricks.
Re: trans slipping, Go back w/727 or glide? [Re: rtstreet] #252169
03/13/09 09:19 AM
03/13/09 09:19 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Your 60 foot times will likely slow to about 1.38-1.40 range, depending on rear gear choice. Worse if you miss on converter selection. There are many pro/cons to either choice.
Considering you have stealth heads, instead of Edelbrocks or Indys, I'm gonna guess the budget is tight, and to do the PG swap right will easily set you back 2 grand, and that's a basic sportsman glide. On the other hand, a top of the line Griner Brake with LB apply for the 727 is 700$.
How many runs on the 727? Without a brake, we used to run basically stock 727s with transgo FM shift kits at that Hp/Weight level for 3 or 4 hundred passes between clutch replacements.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: trans slipping, Go back w/727 or glide? [Re: challenger73400] #252170
03/14/09 10:00 AM
03/14/09 10:00 AM
NC
440Jim Offline
440Jim  Offline
NC
I like the 727, but for your application with a light vehicle and only running to 600 ft, the PG would make sense. The 1.76/1.80 first gear and all the gear you want in the back (5.13?) since you don't have to worry about running the 1/4 mile. But then it will overrev if you race at another track (1/4 mile).
A simple 727 freshen up with a good valve body is all you need, IMO. And that would be a good low dollar approach.
Re: trans slipping, Go back w/727 or glide? [Re: 440Jim] #252171
03/14/09 11:30 AM
03/14/09 11:30 AM
southwest Alabama
southwest Alabama
Thanks for all the help. I've got over 300 passes on the old motor with this trans. running 4.56 gears on a 32" tire. My cheateth vb does not have low band apply but I'm very careful to not roll the tires in first, start my burnout in 2nd and nobody else drives the truck.
I guess I'll save the expense of going with a glide and take the best hard parts from both trans I have, get some good clutches and bands and put in a bolt in spag. Any thing else?
Re: trans slipping, Go back w/727 or glide? [Re: challenger73400] #252172
03/14/09 11:57 AM
03/14/09 11:57 AM
gregsdart Offline
gregsdart  Offline
One thing i learned, once metal filings show up anywhere that they can get back into the trans fluid system, you need to either change coolers or add a filter between cooler and trans. Stuff just never comes loose during a flush and cleanup completely, and cost me another build at one time.
