trans slipping, Go back w/727 or glide?
#252160
03/12/09 11:32 PM
03/12/09 11:32 PM
Posts: 303 southwest Alabama
challenger73400
southwest Alabama
Well, after a few runs with the new motor the trans started sliding on the 2-3 shift. I made it to the finals Sat nite (finished runner up) but the motor flared on the 2-3 shift. Since putting the new motor in it the 2-3 shift has been a bit soft. Anyway, now I gotta build a trans. I'm running a 470 w/stealth heads and turning 6.06 on a 600' track.(about 10.20 in the full 1/4)2800# Dakota I have a spare 727 out of a motorhome that should have the 5 disk clutch in it. Should I put a 727 together with a few good parts or go with a glide, witch means modifiy cross member, new drive shaft, adapter kit, shifter, converter? P.S. I had a 1.341 60ft Sat nite so its leaving hard for my et.
Re: trans slipping, Go back w/727 or glide?
[Re: challenger73400]
#252162
03/12/09 11:39 PM
03/12/09 11:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Would be alot cheaper to just rebuild what you have (or the other 727) you would most likely loose some on your 60' if you changed over to the glide... unless you have a wheel stand problem
[Re: MR_P_BODY]
#252163
03/12/09 11:41 PM
03/12/09 11:41 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
I'm sure you know this, but give the converter a good flush before you put it back in your rebuilt 727
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Post deleted by Defbob
#252164
03/12/09 11:42 PM
03/12/09 11:42 PM
#252166
03/12/09 11:57 PM
03/12/09 11:57 PM
Posts: 2,527 PA
moparacer
PA
I would build a glide....As a matter of fact I just built one for my BB Dart project........
I had a 88 Dakota 360 CID Alky small block that ran 9.77 best and without a doubt the powerglide swap was the best thing I ever did to it......
I have that same glide thats 10 years old fresh and ready to go behind my 7.50 dragster when Ryan gets the engine finished for it.....
No way can anyone on here tell me a 727 is any stronger then a glide if both are done properly......
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: rtstreet]
#252169
03/13/09 09:19 AM
03/13/09 09:19 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Your 60 foot times will likely slow to about 1.38-1.40 range, depending on rear gear choice. Worse if you miss on converter selection. There are many pro/cons to either choice. Considering you have stealth heads, instead of Edelbrocks or Indys, I'm gonna guess the budget is tight, and to do the PG swap right will easily set you back 2 grand, and that's a basic sportsman glide. On the other hand, a top of the line Griner Brake with LB apply for the 727 is 700$.
How many runs on the 727? Without a brake, we used to run basically stock 727s with transgo FM shift kits at that Hp/Weight level for 3 or 4 hundred passes between clutch replacements.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
#252172
03/14/09 11:57 AM
03/14/09 11:57 AM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
One thing i learned, once metal filings show up anywhere that they can get back into the trans fluid system, you need to either change coolers or add a filter between cooler and trans. Stuff just never comes loose during a flush and cleanup completely, and cost me another build at one time.
