Water Pump/Heat Issue #2519997
07/10/18 02:20 PM
07/10/18 02:20 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Trying to help a friend long distance.
Drag only 500"B engine.
Has always been a hot running car and cools back down very slowly.
So he put EVANS COOLANT in it and now goes to 230*at the end of a run.
Sitting in the pits fan and pump running coolant barely trickles through the radiator.
Pull the top hose,turn on pump---nothing flows out!!!.
So,obviously pump is junk.
NO. Took it out fine.
Replaced with an old OEM iron pump,,,,,still no flow.
I am baffled.
Wish I could see it in person.
Ideas? ????
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520014
07/10/18 02:55 PM
07/10/18 02:55 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Hi Dennis,
Is this the waterless evans coolant? I looked at it a bunch a year ago and if i recall, the coolant is much more viscous, and cars run much hotter with it. Also, I thought it is OK to run at high temp without the coolant building pressure. I think it was OK because it keeps the hot spots cooler than with water. Once water becomes vapor, the temp can shoot to the moon.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Water Pump/Heat Issue [Re: oldiron] #2520030
07/10/18 03:37 PM
07/10/18 03:37 PM
N.E. Ohio
N.E. Ohio
Hey,Greg
Yeah I read about the heat reading hotter even though the engine is actually cooler.
Yes waterless.
I wondered if the thicker fluid was just slower flowing.
But he has basically NO flow.
As I said,he said he took the upper hose off and ZERO flow.
I suggested that he put straight water back in and see what happens.
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520041
07/10/18 04:01 PM
07/10/18 04:01 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Thermostat?
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520042
07/10/18 04:04 PM
07/10/18 04:04 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Do you know if he had all of the water out of the system before putting in the EVANS?
Sounds like its worth going back to water
I always wanted to try it, but I guess its not really NHRA approved. I am interested to see how it works out for him. Also, if I remember, Hemi Fred used it in his duster. You might search for his comments. (a long time ago now)
Thermostat...forgot about that little item
See you at NTR?
Re: Water Pump/Heat Issue [Re: oldiron] #2520095
07/10/18 05:36 PM
07/10/18 05:36 PM
N.E. Ohio
N.E. Ohio
No thermostat.
I plan on attending Mopar nats, I will look you up.
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520105
07/10/18 06:11 PM
07/10/18 06:11 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Sounds like a restriction on the feed side - could be the radiator is plugged up or restricted. Is the bottom hose collapsing? The pump can spin all day but if the system has no flow it will not circulate the water through the pump
Re: Water Pump/Heat Issue [Re: DoubleD] #2520108
07/10/18 06:18 PM
07/10/18 06:18 PM
N.E. Ohio
N.E. Ohio
He said he flushed it out when changing coolant,appeared normal/OK.
Electric belt driven pump Moroso?.
The block is poured,but has been in service about 15 years,so if it was too high it surely would have been an issue before unless it is the waterless EVANS stuff?
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520131
07/10/18 06:59 PM
07/10/18 06:59 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
read my last post about the coolant filter
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2518457/2/how-to-cool-my-505.html
Re: Water Pump/Heat Issue [Re: CSK] #2520329
07/11/18 01:04 AM
07/11/18 01:04 AM
As said, first find out/fix what is slowing/restricting the flow (block/head/gasket restriction/rad restriction/low pulley ratio/pump vanes too far away from a stackup of tolerances (long shot but just sayin).
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520395
07/11/18 09:56 AM
07/11/18 09:56 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
People still run those?? - I would not be surprised that it has slowed or is not operating all the time - those things are nothing more than an old fan motor!
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520473
07/11/18 12:31 PM
07/11/18 12:31 PM
Minn
SportF Offline
SportF  Offline
Minn
When the pump is working, and no thermostat, water will come out of that top hose like a washing machine dumping its load into the sink!
It will just pour out of there and shoot 3-4 feet as it does!
(you gotta ask yourself, "how does he know this?")
Good luck!
Re: Water Pump/Heat Issue [Re: DoubleD] #2520540
07/11/18 02:31 PM
07/11/18 02:31 PM
N.E. Ohio
N.E. Ohio
HEY,I still use one too. Old car /old parts/old driver LOL
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520543
07/11/18 02:35 PM
07/11/18 02:35 PM
I would have him remove the lower radiator hose and do a flow test with a garden hose through the radiator cap to see if the radiator will flow out all the water the garden hose will fill the radiator with wrench
If it won't it may be plugged up from the block filler now shruggy
Re: Water Pump/Heat Issue [Re: 6bblFLASH] #2520648
07/11/18 05:36 PM
07/11/18 05:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Good point.
Another good reason to try one of those coolant filters.
