Re: How to cool my 505
[Re: Smoparmike]
#2518671
07/07/18 01:57 AM
07/07/18 01:57 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
One quick trick. Dump your coolant, flush and put one bottle of Redline Water Wetter and straight water. We dropped 15 deg doing just this. https://www.redlineoil.com/waterwetter
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ProSport]
#2518701
07/07/18 06:21 AM
07/07/18 06:21 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My Duster is a mid 10 second street car with a mild 500" motor, high volume mechanical water pump and aluminum housing from Mancini, along with a Northern aluminum radiator. I use a black plastic flex fan, car never runs hot.
The key factor was the shroud. Without a shroud the motor would get hot, with a crappy shroud it was much better but would eventually get hot.
Now I have a custom fit aluminum shroud and I can drive it all day in the heat. The shroud is on the same angle as the fan, and the fan blades stick out of the shroud about half way. That's one nice looking shroud. If you don't mind can I ask what brand it is or who made it and what it cost ? Thanks , Ron
[Re: Smoparmike]
#2518704
07/07/18 07:44 AM
07/07/18 07:44 AM
Posts: 17,920 Akron, Ohio
ProSport
Akron, Ohio
It's just the Northern aluminum shroud kit that came with the radiator.
[Re: 383man]
#2518712
07/07/18 09:10 AM
07/07/18 09:10 AM
Posts: 2,256 IL
furious70
IL
Another pic of my shroud. You can also use a longer spacer and put the fan a bit closer to my rad which I did later. Ron Ron - what are the dimensions of your rad? I've got a universal cross flow in my charger and have been looking for a shroud that is 'close enough' to adapt to fit.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Smoparmike]
#2518836
07/07/18 02:10 PM
07/07/18 02:10 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
The 440 source pump & housing work great, it gets over 105 here in Southeast Tx, my 68 Charger 512 , COLD ac will run 180 all day long, sitting in traffic or 100 + MPH, ECP radiator 2 row, 18" 7 blade direct& a fan shroud Timing 24 initial 36 total,10 more in the vacuum adv hooked up to ported vac.
[Re: Smoparmike]
#2519007
07/07/18 10:49 PM
07/07/18 10:49 PM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I have a street/strip 511 and use the 26" ECP radiator without core support mods as well. nice piece. I use a shroud from jegs that is a 69 charger replica with a flex a lite alum/steel fan and mechanical milodon hi volume pump. No thermostat and evans coolant. Cools fairly well. On a 85* day about 190* was normal water temp until i mounted an oil cooler to the front of the radiator. Now 195* and at 90*+ day 200-205*. I dont usually drive the car at any thing over 85* air temp anyway. The shroud from jegs is a nice piece and fits real nice as well. Oh, one other thing. My block is filled with hard block damn near to the deck. Hope this helps
[Re: furious70]
#2519082
07/08/18 03:48 AM
07/08/18 03:48 AM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
I used a 68 camaro shroud on a crossflow Afco ali radiator in a 65 plymouth
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: furious70]
#2519086
07/08/18 05:34 AM
07/08/18 05:34 AM
383man
Balt. Md
Another pic of my shroud. You can also use a longer spacer and put the fan a bit closer to my rad which I did later. Ron Ron - what are the dimensions of your rad? I've got a universal cross flow in my charger and have been looking for a shroud that is 'close enough' to adapt to fit. I will have to measure it as its been in there since 2010. I got it from Mancini and I told them it was for my 63 and the guy knew which one would fit. But I forgot the exact size so I will try and measure it tomorrow. Ron
[Re: Smoparmike]
#2519263
07/08/18 07:30 PM
07/08/18 07:30 PM
mopar dave
Mt Morris Michigan
the jegs shroud is $149 and replica of 67-69 B body, but works perfect in my A body. Heres a couple pics of my combo to give some ideas. Just went for a short 20 minute cruise in 87* weather and temps were 200* coolant and 200* oil. 205* in stop and go traffic. I would like it cooler, but i'll live with it.
[Re: Smoparmike]
#2519488
07/09/18 01:38 PM
07/09/18 01:38 PM
Posts: 3,916 usa
lewtot184
usa
i've been following this thread because I've always been chasing a heat problem in one of my cars. all of this got me thinking so yesterday I went out in the garage and done something. my 69 r/t is a problem child; all iron stock 440 with a 22" radiator. the stock core only had 76 tubes (2 row), so I upped that to 144 tubes (3 row) several years ago; not a lot of difference. last summer I went thru the engine, nothing special just gaskets, seals, but I did replace the pistons and the rings seemed to have a lot of tension. I also put in a 440 source water pump and new mr.gasket 160 thermostat. had the car out last Saturday, very nice low humidity 81 degree day, and the engine went 210F+ in traffic and stops and would never recover or budge off that 210 even when I got moving.
yesterday I took the thing apart, put a plug in the bypass (but did drill a 1/8" hole in the plug. this is very simple to do by running a 1/4" pipe tap thru the bypass hole.). replaced the 440 source pump with a 6 blade pump (larger o.d. than stock vanes) with the anti-cavitation disc, put in an ancient stant brass 160 thermostat. I did richen the idle mix a little also. started it up this morning and went for a drive. 83-84 degree morning here with high humidity. I didn't get stuck in a lot of traffic but did stop twice and turn the engine off for a few minutes. temps climbed to 210 with the engine sitting but when I did re-start the engine temps began to recover some. driving temps were a little cooler, (no 200+, about 185-190 the highest). I believe there was a real difference in the changes; not huge but enough to restore some comfort level. I believe the pump change plus the bypass plug are improvements. meaningful improvements with this car are hard to come by. it's a shame that temps dampen driving this car because it drive so nicely.
my other car is a 65 coronet; 440, alum heads, headers, small cam, ch28. it has a 22" brass radiator (former a/c car with the inlet on the passenger side) 204 tubes. this thing won't run hot if you drove it thru hell. I use a 180 'stat but, the carbs don't like much heat (heat transfer from heads to intake manifold). ironically the r/t's stock avs doesn't seem to be affected at all by the heat. two cars are as different as dr. Jekyll and mr. hyde.
[Re: Smoparmike]
#2519507
07/09/18 02:21 PM
07/09/18 02:21 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Lew, you should try either a real “high flow” thermostat, or drill a few 1/4” holes in the one you have.
You shouldn’t try blocking the bypass in the housing without there being some other means of bypass available...... which would be the heater core.
As another experiment, along with drilling holes in the stat, you could try plugging(not looping) the heater hose fittings and seeing what(if any) impact that has on the temps.
With the bypass blocked, and no heater hose bypassing(the holes in the stat become the bypass), all the coolant is pumped through the radiator.
[Re: fast68plymouth]
#2519550
07/09/18 03:12 PM
07/09/18 03:12 PM
Posts: 3,916 usa
lewtot184
usa
With the bypass blocked, and no heater hose bypassing(the holes in the stat become the bypass), all the coolant is pumped through the radiator. I do have a high flow thermostat. I do run a heater, so are you suggesting keeping flow thru the heater core with the bypass 90% blocked? what are the effects of not having a bypass and flow to the heater core closed off? I almost did the bypass thing last summer but wasn't sure about the effects. all I know is there were some positive effects from using a traditional type pump and bypass restricting. upping the learning curve here. very helpful comments/posts.
