help picking a carb ???? #2520173
07/10/18 08:08 PM
07/10/18 08:08 PM
IL us
I
ink Online content OP
ink  Online Content OP
I
IL us
I'm looking replace the carb on my 69 super bee (all original and stock 383 4 speed ) thinking Edelbrock 650 ??? what say you ????? if you have a carb # also that would be helpful …. thanks I really would like to start putting some miles on this car !!!!!
Re: help picking a carb ???? [Re: ink] #2520210
07/10/18 09:06 PM
07/10/18 09:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Edelbrock has a series that's a copy of the Carter AVS, up to 800 CFM if I recall, as well as a new AVS II model. Also, call Scott Smith @ Harms Auto (member here) and see what he wants to go through your carb. I'll assume the car has its original AVS?
Re: help picking a carb ???? [Re: ink] #2520234
07/10/18 09:51 PM
07/10/18 09:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the edelbrock 650 is nearly identical to a stock 383avs in size. should make a nice replacement.
Re: help picking a carb ???? [Re: topside] #2520248
07/10/18 10:18 PM
07/10/18 10:18 PM
IL us
I
I
IL us
I do have the original . the car runs very strong. I have to prime the carb to start and if it sits over 35 ~ 40 minutes I will have to reprime carb . Car can sit up 25 ~ 30 minutes and still start . I have replaced the fuel pump already. I have other mopars with same 383 4 speeds that can use a carb …. so I'm thinking if it fixes the problem I will them have the original rebuilt and still use the new carb ????? and be driving my Bee !!!
Re: help picking a carb ???? [Re: ink] #2520263
07/10/18 10:53 PM
07/10/18 10:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
new carb probably won't fix needing to prime the carb every 35-40 minutes. address that problem first before you spend several hundred dollars.
Re: help picking a carb ???? [Re: ink] #2520356
07/11/18 02:48 AM
07/11/18 02:48 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
holley 750 v s
even chry recomended using the larger 440 carb on the 383 magnum !
Re: help picking a carb ???? [Re: ink] #2520397
07/11/18 10:08 AM
07/11/18 10:08 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Do you have the exhaust cross-over blocked? If not, the heat can boil these new fuel blends out of some carbs in a short time. The Carters seem to be more prone to this than the Holleys.
A good insulator between the intake and carb is also a good idea.
Master, again and still
Re: help picking a carb ???? [Re: DaveRS23] #2520420
07/11/18 11:02 AM
07/11/18 11:02 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
this is what I do and it makes a tremendous difference.
Re: help picking a carb ???? [Re: DaveRS23] #2520699
07/11/18 07:21 PM
07/11/18 07:21 PM
IL us
I
I
IL us
THANK YOU !!! will do ….
Re: help picking a carb ???? [Re: ink] #2520713
07/11/18 08:15 PM
07/11/18 08:15 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Where in Il are you?
