Re: help picking a carb ????
[Re: ink]
#2520397
07/11/18 10:08 AM
07/11/18 10:08 AM
Posts: 12,111 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Do you have the exhaust cross-over blocked? If not, the heat can boil these new fuel blends out of some carbs in a short time. The Carters seem to be more prone to this than the Holleys.
A good insulator between the intake and carb is also a good idea.
Master, again and still
[Re: DaveRS23]
#2520420
07/11/18 11:02 AM
07/11/18 11:02 AM
Posts: 3,916 usa
lewtot184
usa
A good insulator between the intake and carb is also a good idea. this is what I do and it makes a tremendous difference.
[Re: DaveRS23]
#2520699
07/11/18 07:21 PM
07/11/18 07:21 PM
Posts: 404 IL us
ink
IL us
THANK YOU !!! will do ….
