Am I dyslexic? Shifter adjustment question #2512324
06/23/18 10:03 PM
06/23/18 10:03 PM
New Mexico
Adobedude Offline OP
New Mexico
EDIT:
Problem found...
the first portion of the Morse cable came out of the second portion and was riding on the threaded rod allowing the cable to flex....
Good cable on top, bad cable on the bottom.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512326
06/23/18 10:10 PM
06/23/18 10:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By Adobedude
Went from Cope Reverse manual valve body to a Cope T Brake valve body, trying to adjust the B&M Ratchet shifter I've used for years.
Long story short, and I've burned up the internet looking...
With the lever on the transmission all the way forward, is that now 3rd gear, and do I adjust it with the shifter pulled all the way back to 3rd?
Nothing I do seem to do works.
all the way forward is high gear, always use neutral as my alignment point and check park and high gear to make sure the cable end slips in the arm on the tranny freely in all 3 spots.
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512327
06/23/18 10:12 PM
06/23/18 10:12 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Wouldn't it be easier to put the trans in park and the shifter in park and adjust the cable so it fits without binding shruggy
I'm a stick guy so it seems too easy to me.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512328
06/23/18 10:13 PM
06/23/18 10:13 PM
New Mexico
New Mexico
So all the way forward is 3rd...3 clicks back is neutral..?
Don't know why this is kicking my butt this time.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512331
06/23/18 10:21 PM
06/23/18 10:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
yep,or you can do as Gus said and use park and check it in neutral then high, I do this to make sure the arm ratio is correct through out the full travel of the linkage, if it is the one that came with the shifter it should be correct.
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512338
06/23/18 10:37 PM
06/23/18 10:37 PM
New Mexico
New Mexico
No change on the shifter...
If I disconnect the cable from the arm on the valve body, it shifts like a breeze.
If I cycle through the shift points on the transmission using the 3" arm on the transmission, again, no issues.
But no matter what I do, or how I hook it up, when I shift from 3rd back to park and pull the locator out of the shift lever I'm a half inch off and two more shifts left on the arm.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512350
06/23/18 11:05 PM
06/23/18 11:05 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
did you buy a VB with clean neutral??
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512362
06/23/18 11:14 PM
06/23/18 11:14 PM
New Mexico
New Mexico
Not unless John Cope sent me one by mistake.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512364
06/23/18 11:15 PM
06/23/18 11:15 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Something doesn't sound right. Never had one that far off. I start in neutral and check every gear detent.
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512374
06/23/18 11:25 PM
06/23/18 11:25 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I start in neutral and just check every gear after that.
I did just F up on my adj. and burned up 2nd gear band and 6 clutches .
So this time I triple checked it .
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512375
06/23/18 11:26 PM
06/23/18 11:26 PM
New Mexico
New Mexico
I'll pull the valve body tomorrow, probably the 6th time it's been out, but I've had nothing but problems on install.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512386
06/23/18 11:49 PM
06/23/18 11:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the rooster tail. Compare it to the other vb.
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512392
06/23/18 11:54 PM
06/23/18 11:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'm with rick.... assuming you are using the same lever. measure the shift points. something like bolting the valve body to a square of plywood so they are both referenced in the same position. put a longer pointer on the shift arm and mark the points between the two. go through the sweep and mark positions. That sucks. assuming you are using the newer billet piece. does the rooster appear the same?
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512394
06/24/18 12:02 AM
06/24/18 12:02 AM
New Mexico
New Mexico
I'll have to pull the valve body, once again...Thankfully it's still dry.
I'm going to bolt the old manual body in and see how works with that, little frustrated, 2nd Mopar points race tonight, I'm the defending champion and I'm spending the evening at home.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512526
06/24/18 12:01 PM
06/24/18 12:01 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
is there a possability that the arm is turning on the post from the pinch bolt not tightening down properly or the split has butted together from overtightening and not tightening around the post and the flat enough to keep it from spinning a little?
Re: Am I dyslexic? Shifter adjustment question [Re: dartman366] #2512647
06/24/18 04:01 PM
06/24/18 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not likely due to the "D" shaped hole in the shift lever but one rare possibility is a loose shift shaft in the roostercomb. The shift shaft has splines and is staked in the roostercomb, sometimes the staking loosens and there is slop in the shaft.
With the shift lever installed on the VB, check for any lost motion (slop) in the lever between detents, especially when changing direction from forward to back.
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512704
06/24/18 07:22 PM
06/24/18 07:22 PM
New Mexico
New Mexico
I edited the first post...
Thanks guys, I figured it out.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512708
06/24/18 07:32 PM
06/24/18 07:32 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
Be careful, i have had my 904 out many times and my Turbo Action shifter adjustment has always been spot on, last time I rushed the installation to make the Bracket Finals towed over two hours away and broke the trans on the first time shot. I had the shifter so far out of adjustment that it burnt the trans and I ended up a spectator after racing all year to qualify for the team. After I had the trans repaired I must have checked the shifter a dozen times to make sure it was correct.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512728
06/24/18 08:11 PM
06/24/18 08:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Glad to see you found the problem. up
Re: Am I dyslexic? Shifter adjustment question [Re: Adobedude] #2512750
06/24/18 09:13 PM
06/24/18 09:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
What did you find?
