Am I dyslexic? Shifter adjustment question
#2512324
06/23/18 10:03 PM
06/23/18 10:03 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
EDIT: Problem found...
the first portion of the Morse cable came out of the second portion and was riding on the threaded rod allowing the cable to flex....
Good cable on top, bad cable on the bottom.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Am I dyslexic? Shifter adjustment question
[Re: Adobedude]
#2512326
06/23/18 10:10 PM
06/23/18 10:10 PM
dartman366
Mt. Vernon, Ohio
Went from Cope Reverse manual valve body to a Cope T Brake valve body, trying to adjust the B&M Ratchet shifter I've used for years. Long story short, and I've burned up the internet looking... With the lever on the transmission all the way forward, is that now 3rd gear, and do I adjust it with the shifter pulled all the way back to 3rd?
Nothing I do seem to do works.
all the way forward is high gear, always use neutral as my alignment point and check park and high gear to make sure the cable end slips in the arm on the tranny freely in all 3 spots.
[Re: Adobedude]
#2512327
06/23/18 10:12 PM
06/23/18 10:12 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Wouldn't it be easier to put the trans in park and the shifter in park and adjust the cable so it fits without binding I'm a stick guy so it seems too easy to me. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Adobedude]
#2512328
06/23/18 10:13 PM
06/23/18 10:13 PM
Adobedude
New Mexico
So all the way forward is 3rd...3 clicks back is neutral..? Don't know why this is kicking my butt this time.
[Re: Adobedude]
#2512331
06/23/18 10:21 PM
06/23/18 10:21 PM
dartman366
Mt. Vernon, Ohio
So all the way forward is 3rd...3 clicks back is neutral..? Don't know why this is kicking my butt this time. yep,or you can do as Gus said and use park and check it in neutral then high, I do this to make sure the arm ratio is correct through out the full travel of the linkage, if it is the one that came with the shifter it should be correct.
[Re: Adobedude]
#2512338
06/23/18 10:37 PM
06/23/18 10:37 PM
Adobedude
New Mexico
No change on the shifter... If I disconnect the cable from the arm on the valve body, it shifts like a breeze. If I cycle through the shift points on the transmission using the 3" arm on the transmission, again, no issues. But no matter what I do, or how I hook it up, when I shift from 3rd back to park and pull the locator out of the shift lever I'm a half inch off and two more shifts left on the arm.
[Re: Adobedude]
#2512350
06/23/18 11:05 PM
06/23/18 11:05 PM
dartman366
Mt. Vernon, Ohio
did you buy a VB with clean neutral??
[Re: Adobedude]
#2512362
06/23/18 11:14 PM
06/23/18 11:14 PM
Adobedude
New Mexico
Not unless John Cope sent me one by mistake.
[Re: Adobedude]
#2512375
06/23/18 11:26 PM
06/23/18 11:26 PM
Adobedude
New Mexico
I'll pull the valve body tomorrow, probably the 6th time it's been out, but I've had nothing but problems on install.
[Re: Adobedude]
#2512394
06/24/18 12:02 AM
06/24/18 12:02 AM
Adobedude
New Mexico
I'll have to pull the valve body, once again...Thankfully it's still dry. I'm going to bolt the old manual body in and see how works with that, little frustrated, 2nd Mopar points race tonight, I'm the defending champion and I'm spending the evening at home.
[Re: Adobedude]
#2512526
06/24/18 12:01 PM
06/24/18 12:01 PM
dartman366
Mt. Vernon, Ohio
is there a possability that the arm is turning on the post from the pinch bolt not tightening down properly or the split has butted together from overtightening and not tightening around the post and the flat enough to keep it from spinning a little?
[Re: dartman366]
#2512647
06/24/18 04:01 PM
06/24/18 04:01 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
is there a possability that the arm is turning on the post from the pinch bolt not tightening down properly Not likely due to the "D" shaped hole in the shift lever but one rare possibility is a loose shift shaft in the roostercomb. The shift shaft has splines and is staked in the roostercomb, sometimes the staking loosens and there is slop in the shaft. With the shift lever installed on the VB, check for any lost motion (slop) in the lever between detents, especially when changing direction from forward to back.
[Re: Adobedude]
#2512704
06/24/18 07:22 PM
06/24/18 07:22 PM
Adobedude
New Mexico
I edited the first post... Thanks guys, I figured it out.
[Re: Adobedude]
#2512708
06/24/18 07:32 PM
06/24/18 07:32 PM
Posts: 4,987 new jersey usa
11secdart
new jersey usa
Be careful, i have had my 904 out many times and my Turbo Action shifter adjustment has always been spot on, last time I rushed the installation to make the Bracket Finals towed over two hours away and broke the trans on the first time shot. I had the shifter so far out of adjustment that it burnt the trans and I ended up a spectator after racing all year to qualify for the team. After I had the trans repaired I must have checked the shifter a dozen times to make sure it was correct.
[Re: Adobedude]
#2512728
06/24/18 08:11 PM
06/24/18 08:11 PM
dartman366
Mt. Vernon, Ohio
I edited the first post... Thanks guys, I figured it out. Glad to see you found the problem.
