Sure Grip ID please #2510553
06/19/18 10:34 PM
06/19/18 10:34 PM
Long Island, NY
shakerjoe Offline OP
Long Island, NY
Like title says, need help ID'ng this unit, was told it's a 4.56 in good shape,thanks in advance.
Re: Sure Grip ID please [Re: shakerjoe] #2510556
06/19/18 10:42 PM
06/19/18 10:42 PM
Long Island, NY
Long Island, NY
1 more
Re: Sure Grip ID please [Re: shakerjoe] #2510560
06/19/18 10:47 PM
06/19/18 10:47 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Thats a clutch type. The gear ratio can usually be found on the outer section of the ring gear.
Example PIC's in this thread
Re: Sure Grip ID please [Re: UCUDANT] #2510562
06/19/18 10:52 PM
06/19/18 10:52 PM
Long Island, NY
Long Island, NY
Thought it might be, ty...found these #s on gear...
Re: Sure Grip ID please [Re: shakerjoe] #2510563
06/19/18 10:55 PM
06/19/18 10:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Count the teeth and do the math
Don't be the exception.
Re: Sure Grip ID please [Re: shakerjoe] #2510568
06/19/18 11:06 PM
06/19/18 11:06 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
The ring gear teeth # and the pinion gear teeth # are on the ring gear, requires math. 44/9=4.88 gears
68 Charger
70 Cuda
Re: Sure Grip ID please [Re: shakerjoe] #2510570
06/19/18 11:08 PM
06/19/18 11:08 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
44/9 = 4.88 ratio
Looks like a clutch type sure trip. 742 casting is large bearing straight shaft pinion.
The clutches can be replaced if worn.
Overall not a bad score if you need the stump puller gears.
Angry white pureblood male
Re: Sure Grip ID please [Re: ruderunner] #2510795
06/20/18 01:28 PM
06/20/18 01:28 PM
Long Island, NY
Long Island, NY
Thanks for the answers, didn't realize it was that easy to tell the ratio, now that I know what it is I can list it, not going to use it, thanks again.
Re: Sure Grip ID please [Re: shakerjoe] #2510845
06/20/18 02:56 PM
06/20/18 02:56 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
nice I just picked up a whole rear 742 5-13 on a sweet deal not sure if I'm running it already have 4-30 in it
