Are there date codes on 8 3/4 ring gear? pics
#1291673
08/26/12 02:52 PM
08/26/12 02:52 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Just pulled the center section on my 8 3/4 rear. The first time in my life I got NO gear lube on me...I love my 4 post lift. 43 teeth on the ring gear and 11 teeth on the pinion should be 3.91? Everything looks excellent I'm wondering how old the parts are. The case is an antique 657, looks to be a Power Loc inside. Are there any date codes on the ring gear? Here are some pics.
Re: Are there date codes on 8 3/4 ring gear? pics
[Re: DoctorDiff]
#1291681
08/26/12 08:06 PM
08/26/12 08:06 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Looks like the gears were made 11/3/73. You also have a cone sure-grip.
Yes , bolts holding it together on the same end as the ring gear bolts and the teeth of the gears look like <bleep> from all the metal chips that POS deposits in the oil .
[Re: 6bblgt]
#1291682
08/26/12 11:25 PM
08/26/12 11:25 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Doug's:part #2881489 ?? 3.23s (42-13) same as cast number on carrier?? 1-7/8" diameter pinion stem ( 10-spline) ring gear 42-teeth stamped # 2800270 pinion 13-teeth stamped # 2800271 listing shows this Ring & Pinion for use in the following carriers: #2881 488 ('69 & up) #2881 489 ('69 & up) AND/ORpart #3744485 3.23s (42-13) 1-7/8" diameter pinion stem ( 29-spline) ring gear 42-teeth stamped # 2800270 pinion 13-teeth stamped # 3507396 listing shows this Ring & Pinion for use in the following carriers: #2881 488 ('70 & up) #2881 489 ('70 & up) I've found some conflicting additional info - is the above correct?
[Re: 69CoronetRT]
#1291684
08/27/12 12:50 AM
08/27/12 12:50 AM
6bblgt
Las Vegas, NV
So - 10-spline pinion & yoke?
2881489 carrier, cast - 288 = Tuesday, 10/15 ('68) ring gear 8 291 machined? inspected? 1968 Friday, 10/18 ring gear finish machined? Saturday, 10/19/68
[Re: 6bblgt]
#1291686
08/27/12 02:13 AM
08/27/12 02:13 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Dan I honestly don't recall.
FWIW here's the date on the carrier. SPD ~B07
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
