Are there date codes on 8 3/4 ring gear? pics #1291673
08/26/12 02:52 PM
08/26/12 02:52 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
Just pulled the center section on my 8 3/4 rear.
The first time in my life I got NO gear lube on me...I love my 4 post lift.
43 teeth on the ring gear and 11 teeth on the pinion should be 3.91?
Everything looks excellent I'm wondering how old the parts are.
The case is an antique 657, looks to be a Power Loc inside.
Are there any date codes on the ring gear?
Here are some pics.
Re: Are there date codes on 8 3/4 ring gear? pics [Re: KillerBee] #1291674
08/26/12 02:53 PM
08/26/12 02:53 PM
N.E. Ohio
K
K
N.E. Ohio
another pic
Re: Are there date codes on 8 3/4 ring gear? pics [Re: KillerBee] #1291675
08/26/12 02:55 PM
08/26/12 02:55 PM
N.E. Ohio
K
K
N.E. Ohio
Last one
Re: Are there date codes on 8 3/4 ring gear? pics [Re: KillerBee] #1291676
08/26/12 03:57 PM
08/26/12 03:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is the "11 3 73 2" all sequential or is there something else in front of the "3 73 2" ??
Re: Are there date codes on 8 3/4 ring gear? pics [Re: 6bblgt] #1291677
08/26/12 04:07 PM
08/26/12 04:07 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
part #2070300 3.91s (43-11) for #1820657 ('57 & up) and #2070741 ('63 & up)
1-3/8" diameter pinion stem (10-spline)
ring gear 43-teeth stamped #2070225 ('61 & up)
pinion 11-teeth stamped #2070226 or #2931665 ('61 & up)
Re: Are there date codes on 8 3/4 ring gear? pics [Re: KillerBee] #1291678
08/26/12 04:54 PM
08/26/12 04:54 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Looks like the gears were made 11/3/73. You also have a cone sure-grip.
Re: Are there date codes on 8 3/4 ring gear? pics [Re: DoctorDiff] #1291679
08/26/12 05:34 PM
08/26/12 05:34 PM
N.E. Ohio
K
K
N.E. Ohio
Thanks for the info.
Looks like I got an old model case with newer parts.
Re: Are there date codes on 8 3/4 ring gear? pics [Re: KillerBee] #1291680
08/26/12 07:51 PM
08/26/12 07:51 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Mine did
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Are there date codes on 8 3/4 ring gear? pics [Re: DoctorDiff] #1291681
08/26/12 08:06 PM
08/26/12 08:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , bolts holding it together on the same end as the ring gear bolts and the teeth of the gears look like <bleep> from all the metal chips that POS deposits in the oil .
Re: Are there date codes on 8 3/4 ring gear? pics [Re: 6bblgt] #1291682
08/26/12 11:25 PM
08/26/12 11:25 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Doug's:
part #2881489 ?? 3.23s (42-13) same as cast number on carrier??
1-7/8" diameter pinion stem (10-spline)
ring gear 42-teeth stamped #2800270
pinion 13-teeth stamped #2800271
listing shows this Ring & Pinion for use in the following carriers:
#2881488 ('69 & up)
#2881489 ('69 & up)
AND/OR
part #3744485 3.23s (42-13)
1-7/8" diameter pinion stem (29-spline)
pinion 13-teeth stamped #3507396
#2881488 ('70 & up)
#2881489 ('70 & up)
I've found some conflicting additional info - is the above correct?
Re: Are there date codes on 8 3/4 ring gear? pics [Re: 6bblgt] #1291683
08/27/12 12:34 AM
08/27/12 12:34 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Here's the carrier
Seeking:
Re: Are there date codes on 8 3/4 ring gear? pics [Re: 69CoronetRT] #1291684
08/27/12 12:50 AM
08/27/12 12:50 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
So - 10-spline pinion & yoke?
2881489 carrier, cast - 288 = Tuesday, 10/15 ('68)
ring gear 8 291 machined? inspected? 1968 Friday, 10/18
ring gear finish machined? Saturday, 10/19/68
Re: Are there date codes on 8 3/4 ring gear? pics [Re: 6bblgt] #1291685
08/27/12 01:00 AM
08/27/12 01:00 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As a rule of thumb, starting in the '71 model year, third-members came with 29 spline pinion yokes. Previous models used the 10 spline version.
Re: Are there date codes on 8 3/4 ring gear? pics [Re: 6bblgt] #1291686
08/27/12 02:13 AM
08/27/12 02:13 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Dan I honestly don't recall.
FWIW here's the date on the carrier. SPD ~B07
Seeking:
