a body disc brakes used on opposite side
#250972
03/11/09 07:16 PM
03/11/09 07:16 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
i have a 68 barracuda, putting on 73 to 76 disc brakes. i want to put them on the opposite side so i can use my swaybar. my question is. does having the calipar in the back affect the braking. has anybody done this. i know it works. just looking at the braking performance end of it.
thanks dave
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side
[Re: davesmopars]
#250974
03/11/09 08:26 PM
03/11/09 08:26 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
My '68 a-body has the caliper upgrade and their mounted in the front of the '73spindles. I added a larger diameter than stockFirmFeel front swaybar with no issues. The brackets for that specific swaybar use the lower shock mount bolt to attach to the lower control arm.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: davesmopars]
#250975
03/11/09 08:37 PM
03/11/09 08:37 PM
Posts: 5,337 the house on the left.
cogen80
thanks dave
you can swap them side to side with no problems.
[Re: jbc426]
#250976
03/11/09 08:38 PM
03/11/09 08:38 PM
cogen80
have any pictures of that?
[Re: cogen80]
#250977
03/11/09 09:08 PM
03/11/09 09:08 PM
davesmopars
cheshire, ct
the spindles are centered to the ball joint, so you can use them on either side. i am just asking if braking is better with the calipar in the front or in the rear or it doesn't matter.
[Re: cogen80]
#250978
03/11/09 09:08 PM
03/11/09 09:08 PM
jbc426
West Coast, USA
I have some on the computer at home, and if not tonight, I can get some on here tomorrow...
[Re: Jim_Lusk]
#250980
03/11/09 09:36 PM
03/11/09 09:36 PM
davesmopars
cheshire, ct
so your saying keep the calipar in the front. use the 68 stock swaybar and shorten the links. so the calipar clear the swaybar.
[Re: davesmopars]
#250982
03/11/09 09:41 PM
03/11/09 09:41 PM
jbc426
West Coast, USA
From what I've read and heard on this subject, it doesn't matter, front or rear placement. It's the brake line and routing that becomes an issue. I have them on the front on my '68 a-body and on the rear on my '70 e-body using the same spindles, but different calipers and brake lines. Doctor Diff sourced the parts including braided steel lines for the rear mount on the '70 e-body. He rocks when it comes to this stuff!
[Re: davesmopars]
#250983
03/11/09 09:54 PM
03/11/09 09:54 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
The original 68 disc setup had the calipers rear mounted ...
[Re: jbc426]
#250984
03/11/09 10:10 PM
03/11/09 10:10 PM
davesmopars
cheshire, ct
how funny is that, i just talked to him yesterday about rear end stuff. i will give him a call again thanks
[Re: 1965_PLYMOUTH]
#250986
03/11/09 10:17 PM
03/11/09 10:17 PM
JohnRR
yes,the rear mounted calipers are more effective, but we're pretty much limited to disc brake swaps for the 62-65 B body MOPARs, so we put in the 73-76 A body systems with the calipers out front. they lack adequate stopping power in the 1/4 mile stretches with these heavier cars, but believe me when I say, the A body system is "loads" better than the original drum brakes.
Why can't you put them on the rear ?
[Re: 1965_PLYMOUTH]
#250987
03/11/09 10:19 PM
03/11/09 10:19 PM
davesmopars
cheshire, ct
ok but why did you not use them on the rear side.
