a body disc brakes used on opposite side #250972
03/11/09 07:16 PM
03/11/09 07:16 PM
cheshire, ct
davesmopars Offline OP
cheshire, ct
i have a 68 barracuda, putting on 73 to 76 disc brakes. i want to put them on the opposite side so i can use my swaybar. my question is. does having the calipar in the back affect the braking. has anybody done this. i know it works. just looking at the braking performance end of it.
thanks dave
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side [Re: davesmopars] #250973
03/11/09 07:21 PM
03/11/09 07:21 PM
USA
CrAlt Offline
CrAlt  Offline
USA
thanks dave
Makes no differance.
You just have to make sure the bleeder screws are on the top and you may have to come up with something fancy for the brake hose.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: a body disc brakes used on opposite side [Re: davesmopars] #250974
03/11/09 08:26 PM
03/11/09 08:26 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My '68 a-body has the caliper upgrade and their mounted in the front of the '73spindles. I added a larger diameter than stockFirmFeel front swaybar with no issues. The brackets for that specific swaybar use the lower shock mount bolt to attach to the lower control arm.
Re: a body disc brakes used on opposite side [Re: davesmopars] #250975
03/11/09 08:37 PM
03/11/09 08:37 PM
the house on the left.
cogen80 Offline
cogen80  Offline
thanks dave
you can swap them side to side with no problems.
Re: a body disc brakes used on opposite side [Re: jbc426] #250976
03/11/09 08:38 PM
03/11/09 08:38 PM
cogen80 Offline
cogen80  Offline
have any pictures of that?
Re: a body disc brakes used on opposite side [Re: cogen80] #250977
03/11/09 09:08 PM
03/11/09 09:08 PM
cheshire, ct
cheshire, ct
the spindles are centered to the ball joint, so you can use them on either side. i am just asking if braking is better with the calipar in the front or in the rear or it doesn't matter.
mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side [Re: cogen80] #250978
03/11/09 09:08 PM
03/11/09 09:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have some on the computer at home, and if not tonight, I can get some on here tomorrow...
Re: a body disc brakes used on opposite side [Re: jbc426] #250979
03/11/09 09:10 PM
03/11/09 09:10 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
You can also shorten the end links for clearance. Either way works fine.
Re: a body disc brakes used on opposite side [Re: Jim_Lusk] #250980
03/11/09 09:36 PM
03/11/09 09:36 PM
cheshire, ct
cheshire, ct
so your saying keep the calipar in the front. use the 68 stock swaybar and shorten the links. so the calipar clear the swaybar.
mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side [Re: jbc426] #250981
03/11/09 09:39 PM
03/11/09 09:39 PM
cheshire, ct
cheshire, ct
yes send me them. here's my email davesmopars@yahoo.com thanks dave
mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side [Re: davesmopars] #250982
03/11/09 09:41 PM
03/11/09 09:41 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
From what I've read and heard on this subject, it doesn't matter, front or rear placement. It's the brake line and routing that becomes an issue. I have them on the front on my '68 a-body and on the rear on my '70 e-body using the same spindles, but different calipers and brake lines. Doctor Diff sourced the parts including braided steel lines for the rear mount on the '70 e-body. He rocks when it comes to this stuff!
Re: a body disc brakes used on opposite side [Re: davesmopars] #250983
03/11/09 09:54 PM
03/11/09 09:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The original 68 disc setup had the calipers rear mounted ...
Re: a body disc brakes used on opposite side [Re: jbc426] #250984
03/11/09 10:10 PM
03/11/09 10:10 PM
cheshire, ct
cheshire, ct
how funny is that, i just talked to him yesterday about rear end stuff. i will give him a call again thanks
mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side [Re: JohnRR] #250985
03/11/09 10:14 PM
03/11/09 10:14 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
yes,the rear mounted calipers are more effective, but we're pretty much limited to disc brake swaps for the 62-65 B body MOPARs, so we put in the 73-76 A body systems with the calipers out front. they lack adequate stopping power in the 1/4 mile stretches with these heavier cars, but believe me when I say, the A body system is "loads" better than the original drum brakes.
Re: a body disc brakes used on opposite side [Re: 1965_PLYMOUTH] #250986
03/11/09 10:17 PM
03/11/09 10:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why can't you put them on the rear ?
Re: a body disc brakes used on opposite side [Re: 1965_PLYMOUTH] #250987
03/11/09 10:19 PM
03/11/09 10:19 PM
cheshire, ct
cheshire, ct
ok but why did you not use them on the rear side.
mcodecuda@yahoo.com
Re: a body disc brakes used on opposite side [Re: davesmopars] #250988
03/12/09 12:23 AM
03/12/09 12:23 AM
AndyF Offline
AndyF  Offline
Caliper location has nothing to do with brake performance. Put the calipers where they clear but make sure the bleeders point up and that the brake hose is properly routed. Rear hung calipers have a very tiny performance advantage due to the weight being moved further towards the rear of the car. That effect is probably too small to be measured on most cars.
Re: a body disc brakes used on opposite side [Re: jbc426] #250989
03/12/09 01:17 AM
03/12/09 01:17 AM
I used F body hoses & bent the hard line a bit so everything would clear(rear mounted) as I moved the suspension all thru its travel (up/down & left/right)
Re: a body disc brakes used on opposite side [Re: AndyF] #250990
03/12/09 05:21 AM
03/12/09 05:21 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the wheel/rotor when spinning doesn't know which way is up or down. why would it care where it's being "squeezed" at by the caliper?
**Photobucket sucks**
Re: a body disc brakes used on opposite side [Re: 70Cuda383] #250991
03/12/09 06:46 AM
03/12/09 06:46 AM
Grand Rapids, MI
Jim L Offline
super street
Jim L  Offline
super street
Grand Rapids, MI
On my 68 Dart, I mounted them in the rear and used hoses from an 80 Diplomat-those had rear mounted calipers.
