Page 3 of 3 1 2 3
Re: info - 440 Source balanced kit, 505 update [Re: dogdays] #1024408
01/14/12 02:48 AM
01/14/12 02:48 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Hey, who is the guy over there in Aurora selling new aluminum blocks on Craigslist? Is he for real?
R.
World Products aluminum Dodge 440 W block $5375
Looks real, give him a call 303-719-7848
I would go for the Hemi block, same price.
Snap your neck, mega G-force launch, is all I want!
Re: info - 440 Source balanced kit, 505 update [Re: 451Mopar] #1024409
01/25/12 01:23 AM
01/25/12 01:23 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Well the engine is just about done. just need to swap distrubitor, pulleys and motor mounts from the old engine.
Re: info - 440 Source balanced kit, 505 update [Re: 451Mopar] #1024410
01/25/12 01:31 AM
01/25/12 01:31 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
how big is it?
Re: info - 440 Source balanced kit, 505 update [Re: 70blackfish] #1024411
01/25/12 02:03 AM
01/25/12 02:03 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
how big is it?
It's stock
just kidding, 505", 4.25" stroke 0.030" over 440.
Re: info - 440 Source balanced kit, 505 update [Re: 451Mopar] #1024412
01/25/12 09:22 AM
01/25/12 09:22 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
how big is it?
It's stock
nice build...
Re: info - 440 Source balanced kit, 505 update [Re: 451Mopar] #1024413
08/09/12 01:22 AM
08/09/12 01:22 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Thought I'd throw an update in. I have been driving the car and tuning the engine. Right now, I have the disrtubitor curved and set for 16 degrees initial and 35 degrees total, plus about 7-8 degrees vacuum advance. Idle vacuum is only 7-8" @ 900 rpm, the altitude here in Denver really hurts vacuum numbers, but the engine does not sound choppy. I don't recall the jet sizes I'm using, but it is leaned out a bit from the factory setting, and I'm still using the stock accelerator pump cam, discharge nozzles, and secondary spring.
I had to drill 1/8" holes in the throttles to stay out of the transfer slots at idle.
The GlenRay radiator with the Mopar viscous clutch fan and reproduction shroud are working good at cooling the engine even on 100+ degree days.
The transmission clutch still slips under full throttle so I have not chassis dynoed the car.
Today I ordered a Keisler SS700 5-speed, with clutch and all the other parts to swap out the A-833. They have free shipping if ordered before Sept 21st. Delivery expected in October?
I'll have to get some pictures to update this, and let you know how the new transmission works out.
Re: info - 440 Source balanced kit, 505 update [Re: 451Mopar] #1024414
09/13/12 11:32 AM
09/13/12 11:32 AM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Nice build! I have one question on the crank key. Could you use the factory key and just remove some material on the bottom side for it to fit down in the slot? I had heard this was an issue. Thanks, Kevin
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: info - 440 Source balanced kit, my measurements. [Re: 451Mopar] #1024415
09/13/12 12:01 PM
09/13/12 12:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
O/T, but these tools can be very useful for getting that edge off very quickly.
http://www.vargus.com/shaviv/
Boffin Emeritus
Re: info - 440 Source balanced kit, my measurements. [Re: 451Mopar] #2509333
06/16/18 02:02 PM
06/16/18 02:02 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Sort of an update to this old engine build.
The original combination is nice foe a mild engine. Has alot of torque. I never got to the chassis dyno to get numbers.
Since then, I installed the Edelbrock XT EFI system, the Billet specialities Tru-Track system, and Vintage air A/C.
Always making changes, changed out the fuel tank with sump and external EFI pump for the Spectra EFI tank with internal pump, and changing out the original Edelbrock EFI controller to a modern self-learning FAST 2.0 EFI controller. Also adding 4-wheel power disk brakes.
The Keisler LGT-700 5-speed trans is holding up will, but I need to check driveline angles and driveshaft balance as I get a driveline vibration at around 100+ MPH.
Old photo of EFI and Tru-Track:
Re: info - 440 Source balanced kit, my measurements. [Re: 451Mopar] #2509338
06/16/18 02:38 PM
06/16/18 02:38 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
very nice smile
Re: info - 440 Source balanced kit, my measurements. [Re: DoubleD] #2509359
06/16/18 03:49 PM
06/16/18 03:49 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By DoubleD
Balanced kit does not mean ready to run! - as with any racing parts - you have to check the tolerences - tight pins are common place on after market rods - it's so you can fit them to your pins!
iagree
72 Plymouth Roadrunner 11.08@123.25
Page 3 of 3 1 2 3
