Page 1 of 3 1 2 3
Better EFI system? #2504815
06/05/18 02:08 PM
06/05/18 02:08 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi all,
I was hoping to get a EFi system and I wanted to hear people's opinion on which is better Fittech or Holley Sniper EFI?
Mike
1969 Dodge Dart Swinger
Re: Better EFI system? [Re: MikeyT] #2504817
06/05/18 02:12 PM
06/05/18 02:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't have either, but from what I have read, and the people I have spoken with I would go Holley. Seems the fitech has some issues and they don't have much support.
68 Barracuda Formula S 340
Re: Better EFI system? [Re: MikeyT] #2504925
06/05/18 06:35 PM
06/05/18 06:35 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I haven't used the Holley system but have heard they are better than the FiTech. I'd try a Super Sniper if I was going to do a TBI system.
I have the FiTech Go8 1200HP system and it has been working good for me, but the instructions are not that good. The FiTech "command center" fuel pump/surge tank setup seems to be a problem from what is posted on the FiTech facebook users group. Any EFI is going to need a good fuel system to supply the EFI Unit. I'm not sure if Holley supplies fuel filters with their kit? The FiTech does not come with fuel filters, so you need a good filter.
Re: Better EFI system? [Re: MikeyT] #2504929
06/05/18 06:50 PM
06/05/18 06:50 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I also depends what you expect from the EFI system.
Some like a more 'open' system where you can add stuff later on and thinker with more.
Re: Better EFI system? [Re: MikeyT] #2504931
06/05/18 06:53 PM
06/05/18 06:53 PM
Maryland
MoparMike1974 Offline
Maryland
Look into the MSD Atomic setup as well. I have one but have not used it on the street yet. I have it running on a 340 on a test stand and out of the box I was able to fire up the engine and break it in with no problems.
Its a nice basic setup and it will control timing and can trigger fans, etc.
Whatever you decide to get, do not skimp on the fuel pump setup. If you dont get a good pump your pissing in the wind with any brand FI.
Re: Better EFI system? [Re: MikeyT] #2504998
06/05/18 10:15 PM
06/05/18 10:15 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks all. I planned on using the electric pump that comes with the EFI set up. My hope is to have a good working system that starts right away, self tunes itself and doesn’t vapor lock
Mike
Re: Better EFI system? [Re: MikeyT] #2505003
06/05/18 10:34 PM
06/05/18 10:34 PM
AndyF Offline
AndyF  Offline
I'm in the process of installing a Super Sniper on my '65 Coronet. It is a simple system but it still takes a little bit of work to make all of the changes to the fuel system as well as the wiring. You might want to read over the instructions a few times before you buy the kit so you're prepared with all of the parts you need.
Re: Better EFI system? [Re: MikeyT] #2505004
06/05/18 10:35 PM
06/05/18 10:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think what they are telling you is to budget an extra grand for a functional fuel delivery system. Because I can tell you that just putting the included pump in place of the original mechanical pump will not work well.
There are many ways to do it but the labor/cost ratio depends on your skill set and/or check book.
Don't be the exception.
Re: Better EFI system? [Re: MikeyT] #2505005
06/05/18 10:40 PM
06/05/18 10:40 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Good to know!
Re: Better EFI system? [Re: MikeyT] #2505130
06/06/18 10:56 AM
06/06/18 10:56 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
How would people do the plumbing for a job like this with a car that had a mechanical fuel pump? I run a standard 3/8' line with a return line.
Re: Better EFI system? [Re: MikeyT] #2505217
06/06/18 01:57 PM
06/06/18 01:57 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Here is a great deal on the Spectra CR9AFI EFI fuel tank with pump and sending unit for $257.66
https://www.amazon.com/Spectra-Premium-CR9AFI-Classic-Injection/dp/B00LPIP7EK
I think the pump is a 255 lph walbro? Should be good for around 500+ HP
The Tanks Inc Tank is $245 tank only, but you can select different fuel pump modules if you need a larger pump. The 255 LPH pump module is $220.
Sending unit is an additional $35.
http://www.tanksinc.com/index.cfm/page/p...prod/prd484.htm
I would use two 3/8" steel lines, one supply, one return. Likely re-shape then to come up closer to the firewall and install -6AN adaptors to the hard line and then -6AN hose from the hard line adaptors to the EFI fuel rails.
Re: Better EFI system? [Re: MikeyT] #2505224
06/06/18 02:04 PM
06/06/18 02:04 PM
dogdays Offline
dogdays  Offline
Simple to describe. Mount the electric fuel pump as close to the gas tank as you can. In the gas tank is even better.
Disconnect the mechanical fuel pump and install a blockoff plate.
Connect the frame fuel line to the engine fuel line. Connect the return line to the regulator return port if it has one.
Figure out where to get power for the fuel pump.. you need enough amps to run the pump and the power has to be switched with the ignition. Consider hiding a switch in the power line as an antitheft device.
R.
Re: Better EFI system? [Re: 451Mopar] #2505258
06/06/18 03:18 PM
06/06/18 03:18 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I also have the Go8 1200 hp system on a 543. I am working through it but all I am going to say is the same thing the shop told me when I picked it up. "Good Luck"
The shop I use has gone above and beyond trying to get it right. They aren't Fuel Injection experts but they are very very good mechanics and can make a carbed car run right.
Re: Better EFI system? [Re: MikeyT] #2505286
06/06/18 04:13 PM
06/06/18 04:13 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
This is starting to sound ominous, like I am steering on a straight a head course for the Bermuda triangle of fuel!!
Re: Better EFI system? [Re: MikeyT] #2505289
06/06/18 04:16 PM
06/06/18 04:16 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Just installed a Sniper EFI on my 512 stroker a couple weeks ago. There really isn't any aftermarket support for my car in the way of EFI gas tanks, so I ordered the Master Kit which included in the fuel pump and other goodies. Mounted the pump and filters to a piece of aluminum stock that in turned got mounted in front of the tank using the strap bolts. New 3/8" nickle-copper return and supply lines also ran. Had to modify my sender for 3/8" pickup as well using bulkhead connectors.
It's a bit more involved wiring wise than what the marketing leads you to believe, but it worked out great. On the first startup it was pig rich until it got warmed up enough to trigger learning mode. After that and a few miles the A/F ratio was where it needed to be. Startups are instantaneous and I gained quite a bit of power overall (that last bit probably has more to do with the fact the carb was undersized and the fuel lines were replaced). Didn't do anything tuning wise yet aside from answer the initial questions on the handheld.
The Master Kit was $1250, tubing for the feed/return was $120 and add another $300 for fittings and other material.
Re: Better EFI system? [Re: MikeyT] #2505332
06/06/18 06:32 PM
06/06/18 06:32 PM
BDW Offline
BDW  Offline
Did FiTech with Spectra tank, most economical solution I could find.
Used my 5/16" fuel line as the return and added a 3/8" fuel line.
Spectra is an all in one solution and much cheaper than Tanks where you have to buy everything separate.
Re: Better EFI system? [Re: BDW] #2505343
06/06/18 06:50 PM
06/06/18 06:50 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Add to that venting the Spectra tank is much easier. If you have your OEM vapor seperator you sre golden.
Craig
Re: Better EFI system? [Re: denfireguy] #2505373
06/06/18 09:21 PM
06/06/18 09:21 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
I have FiTech on my 451 stroker ( the Holley wasn't available yet). I used the Aeromotive Phantom fuel pump, and used new 3/8 hard line and black braided line to make new fuel lines. I think I have about $1600 in the whole set up, including buying a new fuel tank. That said, the Phantom pump is great. The FiTech still needs some tweaking. I don't have many miles on it yet, so perhaps it needs to keep learning, but so far I can't say it infinitely better than the carb I was running. Starting is about the same. Cold accelerating is way better than the carb, but once the engine is warmed up I can't tell a big difference. I will continue to tweak it, but as of now, I can't honestly say that I would do the fuel injection again. The Phantom pump, however, is awesome.
Re: Better EFI system? [Re: MikeyT] #2505478
06/07/18 04:31 AM
06/07/18 04:31 AM
Maryland
Maryland
https://www.aeromotiveinc.com/product/phantom-340-stealth-fuel-system/
I got the phantom 340 fuel pump. Great pump and installs easily in a stock tank.
Re: Better EFI system? [Re: MoparMike1974] #2505515
06/07/18 10:13 AM
06/07/18 10:13 AM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
Fitech on My 440 with an Aeromotive in tank pump, 3/8 feed 5/16 return line.
On this system the white wire has to have keyed on power. I used diode near the ballast resistor to achieve this. I rushed this part and it is not very pretty.
Hey AndyF, perhaps you could design a simple, attractive plug-n-play diode setup for this application.
nd65
Page 1 of 3 1 2 3
