Timing issue or ?????? Update ..... found problem #2502444
05/30/18 10:59 PM
05/30/18 10:59 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Just had a set of -1s porter along with the intake, now I’m only running 30degs of timing but the car wants to stall, before it was back firing through the intake and now it’s popping through the exhaust.. not much but I can hear it. Any ideas .. my Brian is fried from working on it no stop for 3 days and have had now but problems.. thanks guys
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502447
05/30/18 11:02 PM
05/30/18 11:02 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Recheck the firing order.
[image][/image]
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502451
05/30/18 11:07 PM
05/30/18 11:07 PM
Deerfield, Ohio
Deerfield, Ohio
Did that. This is a crank trigger ignition .. gap was checked lined up with the mag in the wheel.checked timing it was a 26 dregs ... I’m at a lose . I have had the dizzy in and out 20 times. Fazed the cap for number one . I’m just at that point.. seems nothing I do helps
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502455
05/30/18 11:15 PM
05/30/18 11:15 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Put it at 34 degrees. Sure sounds like firing order if you've checked all of the above and it's coil farting through the intake or exhaust...
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502458
05/30/18 11:17 PM
05/30/18 11:17 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Nothing to add on what these guys have said but Im interested to hear the problem.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502463
05/30/18 11:24 PM
05/30/18 11:24 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What ignition are you using? Any retard programs in use? Ign boxes don't last forever,,,don't ask how I know,,,,,,,
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502468
05/30/18 11:29 PM
05/30/18 11:29 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Check your plugs. Check your lash.
You have raw fuel in the exhaust. Plugs should show you where it’s coming from.
Re: Timing issue or ?????? [Re: TRENDZ] #2502489
05/31/18 12:11 AM
05/31/18 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When you started this whole job what were you
doing on the car
wave
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502516
05/31/18 01:12 AM
05/31/18 01:12 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I'm assume your changing the timing at the trigger and not at dist. ?
Re: Timing issue or ?????? [Re: a493demon] #2502533
05/31/18 01:51 AM
05/31/18 01:51 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Check the cap and rotor, What cubic inch and compression?
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502558
05/31/18 06:51 AM
05/31/18 06:51 AM
Deerfield, Ohio
Deerfield, Ohio
All I was doing where the port work to head and intake. I did replace the front seal. This is a 500” 11.1 motor with -1s ...
Re: Timing issue or ?????? [Re: 70dusterjohn] #2502563
05/31/18 07:29 AM
05/31/18 07:29 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Sounds to me like sticking needle and seat in the carb
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503412
06/02/18 12:16 AM
06/02/18 12:16 AM
Deerfield, Ohio
Deerfield, Ohio
Well I went though everything that I can with it , my next step is to replace the box . I have no idea what’s going on. It pops through the headers but then sometimes through the intake . Like that timing is out of wack . But I check double check and triple checked . Even pulled the wire for the tack nothing .. I’m about to give up...😡
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503426
06/02/18 01:09 AM
06/02/18 01:09 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
How old is your fuel?
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503432
06/02/18 01:25 AM
06/02/18 01:25 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Is this the 1st time using the crank trigger? If yes,... Did You lock out the spring advance feature of the distributor?
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503446
06/02/18 02:02 AM
06/02/18 02:02 AM
Cab_Burge Online work
Cab_Burge  Online Work
There are only a few things that can make your motor do what it is doing, blown head gaskets is one, bad distributor cap is another, bad spark plug wires, vacuum leak is another and so on.
I would start with the basics first, compression test, infra red temp gun on the headers after driving it, look very closely inside the distributor cap and so on, one thing at a time scope
Please let us know what you find out up
Re: Timing issue or ?????? [Re: urdustd] #2503501
06/02/18 10:11 AM
06/02/18 10:11 AM
Deerfield, Ohio
Deerfield, Ohio
Fuel is about a year old, head gaskets are new, I was going to change the msd out but I was thinking fuel too. Maybe I’ll try that first since it’s Easy.
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503511
06/02/18 11:10 AM
06/02/18 11:10 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run year old fuel at the start of every season, no issues. Car made it's best pass ever. -1 timing anywhere from 26-34 never a misfire. Like stated, cap, wires, dist timing locked, header leak.
Doug
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503518
06/02/18 11:24 AM
06/02/18 11:24 AM
sgcuda Offline
sgcuda  Offline
How did you phase the distributor? I like to drill a 3/8" hole in line with #1 in an old distributor cap and put a timing light on it to check rotor/plug wire alignment. Do you have a 4/7 swap cam and forgot about it when you reran the plug wires? Did you verify TDC timing marks before you started all of this?
[image][/image]
Re: Timing issue or ?????? [Re: 70dusterjohn] #2503572
06/02/18 01:35 PM
06/02/18 01:35 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Check to make sure the little carbon button is inside your distributor cap...It's easy to miss. DAMHIK.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
