Parking Brake release rod Bushing-69 B body? #2501975
05/29/18 10:03 PM
05/29/18 10:03 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
The bushing is missing for my park brake release rod. Of course, the spring comes through the hole when I release the brake and I push the rod back in manually.
I had a few ideas to make it function well enough quick and dirty.
You guys have any ideas or know where a proper bushing can be bought?
Thanks in advance! Oh yeah, I tried the search function first and it was a fail.
Scott
1969 Super Bee, 383/4 speed
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2501979
05/29/18 10:12 PM
05/29/18 10:12 PM
Mass
charge70 Offline
charge70  Offline
Mass
MegaParts has them.You will need to remove the release rod to install.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Parking Brake release rod Bushing-69 B body? [Re: charge70] #2501991
05/29/18 10:35 PM
05/29/18 10:35 PM
Northern NJ
Northern NJ
I did see it on Mega Parts. It looks like it comes with a rubber grommet and 2 springs. Is the rubber grommet right for 69? For some reason I thought the part was made of plastic or nylon. Not that I am an originality snob. I'm not. The car is a driver.
If it is a common rubber grommet I may just be able to pick one up locally.
Scott
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2502118
05/30/18 07:55 AM
05/30/18 07:55 AM
Mass
charge70 Offline
charge70  Offline
Mass
The grommet is available separately.The part# is 199-DR056.You might be able to find something that works locally,I never tried to.
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2502143
05/30/18 10:29 AM
05/30/18 10:29 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I searched through the local hardware store. If I recall, I found some sort of cord strain relief that I drilled out the inside to fit the rod. It looked different than the stock part, but its not something people notice, so I didn't care.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2502183
05/30/18 11:44 AM
05/30/18 11:44 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I just use an old firewall insulation nail.
Cut the head off leaving a slight shoulder that fits on the hole of the bracket.
Is it perfect > No. but it works perfectly and no one will ever see it anyway
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2502328
05/30/18 05:12 PM
05/30/18 05:12 PM
Northern NJ
Northern NJ
Thank you guys for all the great ideas. It is well appreciated. Charge70, thank you for the part number.
You guys never fail. Thank you again.
Scott
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2502424
05/30/18 09:57 PM
05/30/18 09:57 PM
Chicago
PurpleBeeper Offline
Chicago
I "might" take a look at megaparts, but for now I just cut a notch in a washer, slipped it over the rod (behind bracket) & held it in place with a glob of "dog turd" 2-part epoxy putty.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Parking Brake release rod Bushing-69 B body? [Re: StukaJU87] #2502624
05/31/18 11:33 AM
05/31/18 11:33 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I found bushings that are "close" and work. I'll take a photo and post later.
Re: Parking Brake release rod Bushing-69 B body? [Re: Stanton] #2502770
05/31/18 05:17 PM
05/31/18 05:17 PM
Northern NJ
Northern NJ
Thank you!
Scott
Re: Parking Brake release rod Bushing-69 B body? UPDATE [Re: StukaJU87] #2505712
06/07/18 07:58 PM
06/07/18 07:58 PM
Northern NJ
Northern NJ
I went with a flat washer. I snipped it and spread it then pushed the spring back, slipped the washer on and took a pliers and flattened the washer. Worked like a charm. Can always count on the guys on Moparts to share great knowledge and ideas. Thank you.
Scott
