Parking Brake release rod Bushing-69 B body?
#2501975
05/29/18 10:03 PM
05/29/18 10:03 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
The bushing is missing for my park brake release rod. Of course, the spring comes through the hole when I release the brake and I push the rod back in manually.
I had a few ideas to make it function well enough quick and dirty.
You guys have any ideas or know where a proper bushing can be bought?
Thanks in advance! Oh yeah, I tried the search function first and it was a fail.
Scott
1969 Super Bee, 383/4 speed
Re: Parking Brake release rod Bushing-69 B body?
[Re: StukaJU87]
#2501979
05/29/18 10:12 PM
05/29/18 10:12 PM
Posts: 601 Mass
charge70
Mass
MegaParts has them.You will need to remove the release rod to install.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2501991
05/29/18 10:35 PM
05/29/18 10:35 PM
StukaJU87
Northern NJ
MegaParts has them.You will need to remove the release rod to install. I did see it on Mega Parts. It looks like it comes with a rubber grommet and 2 springs. Is the rubber grommet right for 69? For some reason I thought the part was made of plastic or nylon. Not that I am an originality snob. I'm not. The car is a driver. If it is a common rubber grommet I may just be able to pick one up locally.
Scott
[Re: StukaJU87]
#2502118
05/30/18 07:55 AM
05/30/18 07:55 AM
Posts: 601 Mass
charge70
Mass
The grommet is available separately.The part# is 199-DR056.You might be able to find something that works locally,I never tried to.
[Re: StukaJU87]
#2502143
05/30/18 10:29 AM
05/30/18 10:29 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I searched through the local hardware store. If I recall, I found some sort of cord strain relief that I drilled out the inside to fit the rod. It looked different than the stock part, but its not something people notice, so I didn't care.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: StukaJU87]
#2502328
05/30/18 05:12 PM
05/30/18 05:12 PM
StukaJU87
Northern NJ
Thank you guys for all the great ideas. It is well appreciated. Charge70, thank you for the part number.
You guys never fail. Thank you again.
Scott
[Re: StukaJU87]
#2502424
05/30/18 09:57 PM
05/30/18 09:57 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I "might" take a look at megaparts, but for now I just cut a notch in a washer, slipped it over the rod (behind bracket) & held it in place with a glob of "dog turd" 2-part epoxy putty.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Stanton]
#2502770
05/31/18 05:17 PM
05/31/18 05:17 PM
StukaJU87
Northern NJ
I found bushings that are "close" and work. I'll take a photo and post later. Thank you!
Scott
Re: Parking Brake release rod Bushing-69 B body? UPDATE
[Re: StukaJU87]
#2505712
06/07/18 07:58 PM
06/07/18 07:58 PM
StukaJU87
Northern NJ
I went with a flat washer. I snipped it and spread it then pushed the spring back, slipped the washer on and took a pliers and flattened the washer. Worked like a charm. Can always count on the guys on Moparts to share great knowledge and ideas. Thank you.
Scott
