rod end caps #2501759
05/29/18 02:46 PM
05/29/18 02:46 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
what method do you guys use to get them off.ive never had this much trouble before.eagle h-beam,they are in a motor.
Re: rod end caps [Re: bonefish] #2501774
05/29/18 03:18 PM
05/29/18 03:18 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I undo the bolt about 4 or 5 turns and hit it with a rubber mallet each side or the handle
Re: rod end caps [Re: bonefish] #2501781
05/29/18 03:29 PM
05/29/18 03:29 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I take the jaw inserts off my vise and mount them with just 1 bolt on each side leaving them stick out of one side of the vise. Slid a section of heater hose over them and open the jaws to pull the halves of the rod apart.
Re: rod end caps [Re: Clanton] #2501790
05/29/18 03:48 PM
05/29/18 03:48 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
THANKS,works like a charm up
Re: rod end caps [Re: 67_Satellite] #2501791
05/29/18 03:49 PM
05/29/18 03:49 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
THANKS,but these are in the motor.
Re: rod end caps [Re: Clanton] #2501807
05/29/18 04:21 PM
05/29/18 04:21 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
up iagree
Re: rod end caps [Re: bonefish] #2501892
05/29/18 06:05 PM
05/29/18 06:05 PM
A brass drift on the loosen bolts will drive the rods up away from the caps also scope hammer grin up
Re: rod end caps [Re: Clanton] #2501981
05/29/18 10:14 PM
05/29/18 10:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Same thing here.. thats all I do on any of
my rods
wave
Re: rod end caps [Re: bonefish] #2502055
05/30/18 12:54 AM
05/30/18 12:54 AM
New York, USA
Chargerfan68 Offline
New York, USA
Me too. Same as these guys.
Re: rod end caps [Re: Chargerfan68] #2502074
05/30/18 01:46 AM
05/30/18 01:46 AM
Me too, some judicious easy taps with a piece of wood/small hammer till it starts to move up a bit
Re: rod end caps [Re: bonefish] #2502151
05/30/18 10:54 AM
05/30/18 10:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I use one of these when the rods are out of the car:
https://www.summitracing.com/parts/pro-67905
Re: rod end caps [Re: bonefish] #2502162
05/30/18 11:12 AM
05/30/18 11:12 AM
Sorry. Thats what i get for posting from my phone without glasses.
