Re: rod end caps
[Re: bonefish]
#2501774
05/29/18 03:18 PM
05/29/18 03:18 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I undo the bolt about 4 or 5 turns and hit it with a rubber mallet each side or the handle
Re: rod end caps
[Re: 67_Satellite]
#2501791
05/29/18 03:49 PM
05/29/18 03:49 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I take the jaw inserts off my vise and mount them with just 1 bolt on each side leaving them stick out of one side of the vise. Slid a section of heater hose over them and open the jaws to pull the halves of the rod apart. THANKS,but these are in the motor.
Re: rod end caps
[Re: bonefish]
#2501892
05/29/18 06:05 PM
05/29/18 06:05 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
I take the jaw inserts off my vise and mount them with just 1 bolt on each side leaving them stick out of one side of the vise. Slid a section of heater hose over them and open the jaws to pull the halves of the rod apart. THANKS,but these are in the motor. A brass drift on the loosen bolts will drive the rods up away from the caps also
Re: rod end caps
[Re: Clanton]
#2501981
05/29/18 10:14 PM
05/29/18 10:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I undo the bolt about 4 or 5 turns and hit it with a rubber mallet each side or the handle Same thing here.. thats all I do on any of my rods
Re: rod end caps
[Re: Chargerfan68]
#2502074
05/30/18 01:46 AM
05/30/18 01:46 AM
RapidRobert
Me too, some judicious easy taps with a piece of wood/small hammer till it starts to move up a bit
Re: rod end caps
[Re: bonefish]
#2502162
05/30/18 11:12 AM
05/30/18 11:12 AM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
I take the jaw inserts off my vise and mount them with just 1 bolt on each side leaving them stick out of one side of the vise. Slid a section of heater hose over them and open the jaws to pull the halves of the rod apart. THANKS,but these are in the motor. Sorry. Thats what i get for posting from my phone without glasses.
