Accell dual point #2500217
05/25/18 09:44 AM
05/25/18 09:44 AM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
I'm wanting to use an old school #30302 Accell dual point distributor in my 68 project road runner. Do they still service caps, rotors, points, etc for these? I didn't think the cap was the same as a reg mopar, is it?
Re: Accell dual point [Re: Silverbullet2] #2500545
05/26/18 02:40 AM
05/26/18 02:40 AM
I found one on eBay for you & it takes 2 sets of GM points, the ones that adj the gap with an allen wrench. the rotor has a wide a$$ end which looks like the ones "joesixpack" on here sells for our dual point dists, not a guarantee for fitment tho.
Re: Accell dual point [Re: Silverbullet2] #2500803
05/26/18 09:37 PM
05/26/18 09:37 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
Check Summit, If anybody would have one, it would be them
Re: Accell dual point [Re: Goat330] #2500876
05/27/18 01:06 AM
05/27/18 01:06 AM
there ya go on the points (gm, available), condensor should be a non issue & their capacities vary some. I'm thinking the cap is the same. If the rotor has the seperate short piece of brass that is riveted to it like ours is you could easily drill that out & sub in a new piece as needed if burnt/eroded & that would even let you set the tip to cap terminal gap to .015". EDIT mainly it would be are the bushings still tight as the point tension wears them faster than electronic plus performance point sets have more spring tension (+ 2 sets of points!)
Re: Accell dual point [Re: RapidRobert] #2500886
05/27/18 02:03 AM
05/27/18 02:03 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
These will be Accel numbers, with Delco interchanges.
30302 (all 30000 series are the same) takes
110128 (street) 110129 (race) points ~ 2 sets ~ use: 56-74 GM Delco # D106P or D112P dwell 26* each set, 34-36 total
100107 condenser ~ use: 55-56 Chevy Delco # D203
120123 dist cap ~ use: 55-56 Chevy Delco # D305 Accel used a skinny square cut O ring on originals
130116 rotor ~ use: 55-56 Chevy Delco # D407
Information is from my library of old parts catalogues, a 1977 Accel catalogue in this case.
Re: Accell dual point [Re: Silverbullet2] #2500905
05/27/18 05:50 AM
05/27/18 05:50 AM
BDW Offline
BDW  Offline
That's funny, so the high tech Accel design in the 70s was copied from 50s Chevy?
Re: Accell dual point [Re: BDW] #2500927
05/27/18 10:21 AM
05/27/18 10:21 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Yep, Accel was all about hype. Many factory Chevy and Mopar distributors were way superior, but Accel had the ads in every hot rod type magazine so everyone wanted them.
Re: Accell dual point [Re: Silverbullet2] #2501247
05/28/18 09:37 AM
05/28/18 09:37 AM
North Carolina, USA
North Carolina, USA
Thanks a million John Brown! That is the exact info I was looking for!
