smallest power steering gear box #2500718
05/26/18 05:03 PM
05/26/18 05:03 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
what is the smallest power steering gear that will bolt up to a E-BODY with little to no modification?
Re: smallest power steering gear box [Re: mcat4321] #2500722
05/26/18 05:16 PM
05/26/18 05:16 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Are you looking for header clearance? I think all the stock ones are the same size. I had to go with a manual box in my Dart for TTI headers.
Re: smallest power steering gear box [Re: mcat4321] #2500727
05/26/18 05:44 PM
05/26/18 05:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Borgenson. Spelling may be wrong
Re: smallest power steering gear box [Re: 71birdJ68] #2500751
05/26/18 07:22 PM
05/26/18 07:22 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Borgeson. wink
http://www.borgeson.com/
Did not know they made a smaller box now. Very cool. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: smallest power steering gear box [Re: mcat4321] #2500787
05/26/18 08:44 PM
05/26/18 08:44 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
The borgeson has mixed reviews here, but I think it's a great piece.
Re: smallest power steering gear box [Re: mcat4321] #2500801
05/26/18 09:24 PM
05/26/18 09:24 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Another vote for Borgeson. I've installed two of them and they've been great for a number of years now. Order it through Bergman and use his column adapter.
Re: smallest power steering gear box [Re: mcat4321] #2500917
05/27/18 08:16 AM
05/27/18 08:16 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Borgeson seems to be the only non stock option.
Sorry if i kidnap the topic but i suspect the OP might also be intrested,how is the feel of them? anywhere near stock or do they feel "to modern" ?
Re: smallest power steering gear box [Re: mcat4321] #2500922
05/27/18 10:00 AM
05/27/18 10:00 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
My car has a very similar feel to stock, but faster ratio. I removed all the shims in the valve and drilled the fitting to 5/32. I guess it can be firmed up by adding shims but yes a close to stock feel is possible.
Re: smallest power steering gear box [Re: JAMESDART] #2501008
05/27/18 03:03 PM
05/27/18 03:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What power steering box are you using. Only faster ratio stock mounting box is the borgenson at 14:1. Stock boxes need longer pitman to change ratio.
Re: smallest power steering gear box [Re: JAMESDART] #2501377
05/28/18 05:27 PM
05/28/18 05:27 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Thank you,that is good to know:)
Re: smallest power steering gear box [Re: mcat4321] #2501387
05/28/18 05:54 PM
05/28/18 05:54 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
BORGESON. someone asked if it had a "too modern feel". Mine doesn't feel too firm, but when I replaced the pump I removed all the shims as a starting point.
