Re: smallest power steering gear box
[Re: mcat4321]
#2500722
05/26/18 05:16 PM
05/26/18 05:16 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
what is the smallest power steering gear that will bolt up to a E-BODY with little to no modification? Are you looking for header clearance? I think all the stock ones are the same size. I had to go with a manual box in my Dart for TTI headers.
[Re: mcat4321]
#2500787
05/26/18 08:44 PM
05/26/18 08:44 PM
Posts: 619 nj
JAMESDART
nj
The borgeson has mixed reviews here, but I think it's a great piece.
[Re: mcat4321]
#2500801
05/26/18 09:24 PM
05/26/18 09:24 PM
Posts: 4,421 Michigan
MarkZ
Worthy
Worthy
Another vote for Borgeson. I've installed two of them and they've been great for a number of years now. Order it through Bergman and use his column adapter.
[Re: JAMESDART]
#2501008
05/27/18 03:03 PM
05/27/18 03:03 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
My car has a very similar feel to stock, but faster ratio. I removed all the shims in the valve and drilled the fitting to 5/32. I guess it can be firmed up by adding shims but yes a close to stock feel is possible. What power steering box are you using. Only faster ratio stock mounting box is the borgenson at 14:1. Stock boxes need longer pitman to change ratio.
[Re: JAMESDART]
#2501377
05/28/18 05:27 PM
05/28/18 05:27 PM
Posts: 2,578 sweden
1Fast340
sweden
My car has a very similar feel to stock, but faster ratio. I removed all the shims in the valve and drilled the fitting to 5/32. I guess it can be firmed up by adding shims but yes a close to stock feel is possible. Thank you,that is good to know:)
