big power, boosted G3 overdrive transmission options #2498711
05/21/18 06:24 PM
05/21/18 06:24 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
im building another boosted gen3 hemi car,(70 cuda)in my last car(68 barracuda) i ran a 727, and at low boost it made over 600 at the wheel,
on this build i will be looking at over 1k at the wheel.
i really want to run an overdrive this time, but which one, and who would you have build it? i want to stick to a mopar trans that will easily bolt to a smallblock bolt pattern.. thank
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2498762
05/21/18 08:06 PM
05/21/18 08:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Assuming automatic then the only option is a 46RH, gonna need a lot of upgrades but I think it could be made to work.
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2498780
05/21/18 09:16 PM
05/21/18 09:16 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
I would have ProTrans (Lancaster CA) build a 727 and then put a Gear Vendor OD on it.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2498785
05/21/18 09:26 PM
05/21/18 09:26 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I think the only one capable and reliable at that level is going to be a GearVendors. They have a shorty version now maybe 2. One uses the 4x4 output shaft so it should be pretty close to stock length. They also have one that uses the truck/motorhome trans that is 7 inches longer than a stock 727.
Kevin
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2498844
05/21/18 11:24 PM
05/21/18 11:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would call a diesel place like Goerand or someone like that. They are building OD transmissions that hold up reliably behind 1000+lb/ft cummins engines towing over 20,000 lb loads. The bell housing and converter should be the only difference I would think.
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2498850
05/21/18 11:38 PM
05/21/18 11:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Rossler 4L80E with an aftermarket bell.
68 Barracuda Formula S 340
Re: big power, boosted G3 overdrive transmission options [Re: Bad340fish] #2499127
05/22/18 04:45 PM
05/22/18 04:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
He said mopar trans.
Re: big power, boosted G3 overdrive transmission options [Re: Twostick] #2499178
05/22/18 07:30 PM
05/22/18 07:30 PM
Still wishing...
Still wishing...
Kevin
Measured length is with the GV installed. I see I wasn't clear on that.
Kevin
Re: big power, boosted G3 overdrive transmission options [Re: HotRodDave] #2499182
05/22/18 07:34 PM
05/22/18 07:34 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Build a 46RE and use my trans brake with reverse manual valve body, had harden shafts, Billet drum ect and 1000+ HP is no problem.
Here is my sales pitch:
P NR 1 2 3 4. shift pattern.
NO kick down linkage
NO shift solenoids
NO governor sensors
NO controlle module
CRT has the only trans brake valve body with all gears on the manual valve & Lock up in any & all gears
also fits RH and all RE transmissions.
Re: big power, boosted G3 overdrive transmission options [Re: CRT] #2499277
05/22/18 11:55 PM
05/22/18 11:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
NO shift solenoids
NO governor sensors
NO controlle module
Can you out the power to it in OD as well or should it only be used for cruising?
Re: big power, boosted G3 overdrive transmission options [Re: WO23Coronet] #2499295
05/23/18 12:53 AM
05/23/18 12:53 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Overdrive with my set up is not just for Cruzn. It can take just much as 1 2 3
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2499423
05/23/18 12:06 PM
05/23/18 12:06 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
All good replies here. Biggest problem is that you still need a shield if your doing any sanction racing.
REID case with GEAR VENDOR OD.
Re: big power, boosted G3 overdrive transmission options [Re: CRT] #2499494
05/23/18 02:14 PM
05/23/18 02:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Is the CRT thing a LBA?
Re: big power, boosted G3 overdrive transmission options [Re: Bad340fish] #2499729
05/23/18 11:10 PM
05/23/18 11:10 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
This would be my choice also despite not wanting to go with a gm trans.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: big power, boosted G3 overdrive transmission options [Re: HotRodDave] #2499768
05/24/18 12:12 AM
05/24/18 12:12 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
yes it is.
Re: big power, boosted G3 overdrive transmission options [Re: CRT] #2499786
05/24/18 12:53 AM
05/24/18 12:53 AM
State College, Pennsylvania
fatman Offline
fatman  Offline
Are tunnel mods required for a 46RE into an E Body ?
Re: big power, boosted G3 overdrive transmission options [Re: fatman] #2499805
05/24/18 01:39 AM
05/24/18 01:39 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Yes there is.
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2499808
05/24/18 01:48 AM
05/24/18 01:48 AM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
Re: big power, boosted G3 overdrive transmission options [Re: CRT] #2499822
05/24/18 02:16 AM
05/24/18 02:16 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
CRT, The trans. brake can be applied in any of the 4 forward speeds?
Re: big power, boosted G3 overdrive transmission options [Re: mcat4321] #2499994
05/24/18 02:50 PM
05/24/18 02:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Not on all E bodys are the tunnel mods needed, I know first hand but they do all need a modified cross member.
