Re: big power, boosted G3 overdrive transmission options
[Re: mcat4321]
#2498762
05/21/18 08:06 PM
05/21/18 08:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Assuming automatic then the only option is a 46RH, gonna need a lot of upgrades but I think it could be made to work.
[Re: mcat4321]
#2498780
05/21/18 09:16 PM
05/21/18 09:16 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I would have ProTrans (Lancaster CA) build a 727 and then put a Gear Vendor OD on it.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: mcat4321]
#2498844
05/21/18 11:24 PM
05/21/18 11:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would call a diesel place like Goerand or someone like that. They are building OD transmissions that hold up reliably behind 1000+lb/ft cummins engines towing over 20,000 lb loads. The bell housing and converter should be the only difference I would think.
[Re: mcat4321]
#2498850
05/21/18 11:38 PM
05/21/18 11:38 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Rossler 4L80E with an aftermarket bell.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2499127
05/22/18 04:45 PM
05/22/18 04:45 PM
HotRodDave
Kalispell Mt.
Rossler 4L80E with an aftermarket bell. He said mopar trans.
[Re: Twostick]
#2499178
05/22/18 07:30 PM
05/22/18 07:30 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I think the only one capable and reliable at that level is going to be a GearVendors. They have a shorty version now maybe 2. One uses the 4x4 output shaft so it should be pretty close to stock length. They also have one that uses the truck/motorhome trans that is 7 inches longer than a stock 727.
Kevin Measured length is with the GV installed. I see I wasn't clear on that. Kevin
[Re: CRT]
#2499277
05/22/18 11:55 PM
05/22/18 11:55 PM
Posts: 4,254 Canada
WO23Coronet
Canada
Build a 46RE and use my trans brake with reverse manual valve body, had harden shafts, Billet drum ect and 1000+ HP is no problem. Here is my sales pitch: P NR 1 2 3 4. shift pattern. NO kick down linkage NO shift solenoids NO governor sensors NO controlle module CRT has the only trans brake valve body with all gears on the manual valve & Lock up in any & all gears also fits RH and all RE transmissions. Can you out the power to it in OD as well or should it only be used for cruising?
[Re: Bad340fish]
#2499729
05/23/18 11:10 PM
05/23/18 11:10 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Rossler 4L80E with an aftermarket bell. This would be my choice also despite not wanting to go with a gm trans.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: fatman]
#2499805
05/24/18 01:39 AM
05/24/18 01:39 AM
Posts: 2,771 Cedar Lake IN
CRT
Cedar Lake IN
Yes there is.
[Re: mcat4321]
#2499994
05/24/18 02:50 PM
05/24/18 02:50 PM
HotRodDave
Kalispell Mt.
Not on all E bodys are the tunnel mods needed, I know first hand but they do all need a modified cross member.
