batterys Bosch or interstate #2496095
05/14/18 06:55 PM
05/14/18 06:55 PM
btomasko Offline OP
btomasko  Offline OP
Which is the better battery interstate or bosch,need opinoins and which one would you buy? thanks
Re: batterys Bosch or interstate [Re: btomasko] #2496123
05/14/18 07:49 PM
05/14/18 07:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have not had any issues with Interstate batteries.
Re: batterys Bosch or interstate [Re: btomasko] #2496361
05/15/18 11:32 AM
05/15/18 11:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We sold Interstates at the shop.had maybe 1 or 2 in 15 years that were bad.We run Advance batterys now.Never a problem.I get them discounted because of the shop i worked at and my sons a manager there also.Rocky
Chrysler Firepower
Re: batterys Bosch or interstate [Re: btomasko] #2496652
05/15/18 09:31 PM
05/15/18 09:31 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I'm a huge Interstate user but you might consider Deka Batteries. Most are USA made.
Common sense is a flower that does not grow in everybody's garden
Re: batterys Bosch or interstate [Re: btomasko] #2496701
05/15/18 11:44 PM
05/15/18 11:44 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have bought 3 Group 27 Bosch batteries - all crap
Re: batterys Bosch or interstate [Re: btomasko] #2496722
05/16/18 12:45 AM
05/16/18 12:45 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
I had an Interstate battery go bad. At 2 year, 2 months. So, now for everyday cars, I get a 3 year from Autozone. The old Charger has a fancy Optima.
I used to alway use Interstate, but the 2 year warranty is not enough.
Re: batterys Bosch or interstate [Re: Ron_M] #2496775
05/16/18 10:18 AM
05/16/18 10:18 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
https://www.lowes.com/pd/Deka-12-Volt-81...ByABEgKNL_D_BwE
Lowes Lumber seems to be a nationwide Deka seller.
Is there a less expense seller of Deka?
Marine versus Automotive?
If you have room under the hood
is a Marine rated Deka battery of adequate CCA
likely to last longer
in the road vibration environment of automotive service than
the generally cheaper auto service rated batteries?
I wish that a 1000 owner group of Cummins Ram owners
with dual batteries under the hood
would volunteer to do a long term test
with both a marine and automotive rated battery in parallel service.
Re: batterys Bosch or interstate [Re: 360view] #2497189
05/17/18 01:44 PM
05/17/18 01:44 PM
dogdays Offline
dogdays  Offline
Bosch and Interstate are both Johnson Controls batteries.
IMHO it is more important to get the latest manufactured battery.
360View, you can follow this link: https://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
Auto starting batteries are designed to deliver short jolts of max power. Deep Cycle batteries have less instantaneous current available but can be deeply discharged many more times without damage. Marine batteries need to be able to withstand periods of time without being recharged, like when the boat is sitting and you've got the lights and TV on, or running the refrigerator. Different designs for different uses.
R.
Re: batterys Bosch or interstate [Re: btomasko] #2497263
05/17/18 05:00 PM
05/17/18 05:00 PM
USA
3
360view Offline
360view  Offline
3
USA
The Wiki is pretty good on historical background.
This article in the footnotes is interesting as it describes special test batteries in clear glass cases and experiments with whether Pulse Chargers and Cadnium Sulfate additives can do much beyond recovering about 30% of as new capacity.
http://www.batteryvitamin.net/sulfation_remedies_demystified
Re: batterys Bosch or interstate [Re: btomasko] #2497275
05/17/18 05:39 PM
05/17/18 05:39 PM
an8sec70cuda Offline
I have a pair of Interstate batteries in my Dodge truck that I bought in November 2012. They were bought "new" from the Interstate dealer during a special they had on new old stock batteries. Batteries that had sat on the shelf too long and were being sold a really low discount prices. If they died tomorrow I wouldn't be surprised, but they've lasted a lot longer than I expected them to. Think I paid about $90 for BOTH of them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: batterys Bosch or interstate [Re: btomasko] #2497339
05/17/18 08:14 PM
05/17/18 08:14 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Batteries have been hit or miss for me. I had one last 12 years in my dart, it was some champion tractor battery from sams. No tender or anything. I replaced it with a napa that went bad just out of the warranty, I think that was 1 year? I tried a die hard platinum in the duster that didn't seem to like sitting for long periods. I brought it back they checked it and said it was fine. I put it in wife's jeep and it's been working great. I bought some marine x2 from batteries plus for my off-roader jeep, long reserve and high cranking amps. Best battery I ever owned but also the most expensive. When I sold the jeep I wanted the battery but I had nothing to swap it out. And I figured with my luck I'd replace it with a new cheapie and it wouldn't last me
So I let it go. I'm not sure I'd spend that much on one again
I read a while ago that advance was going to be the exclusive retailer for interstate. I've been looking but haven't seen them in the store yet.
Re: batterys Bosch or interstate [Re: btomasko] #2497352
05/17/18 08:52 PM
05/17/18 08:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
To answer the OP question, I'd go with Interstate, mainly because they're widely available if there's a problem.
I've generally had very good service from batteries, most are Duralast (AutoZone) or Optima reds.
Re: batterys Bosch or interstate [Re: topside] #2497376
05/17/18 10:51 PM
05/17/18 10:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Put a Deka in my car 10 years ago with only summer use and it's still going strong. I think I may just buy another one this year shruggy
Now that I was bragging about it I better change it work
Gus beer
64 Plymouth Savoy
Dana 60
Re: batterys Bosch or interstate [Re: btomasko] #2497379
05/17/18 10:59 PM
05/17/18 10:59 PM
I own a 2006 Ram 3500 CTD 4 Whd that has both the original batteries in it, they acted weak last winter when trying to start it without the block heater hooked up so I went to the local Wal Mart and bought two new Duracell, maybe Everlast, which ever ones Walmart sells, replacement batteries. I plugged the heater in and those batteries are still in the truck now starting it okay.
My message is try to find out who makes those Dodge CTD OEM batteries and buy them up
The OEM batteries in my old 1998 Ram 2500 1/2 CTD truck lasted 11 yrs also before one went bad, the other one lasted 9 months longer work up
Re: batterys Bosch or interstate [Re: btomasko] #2497383
05/17/18 11:09 PM
05/17/18 11:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cab has better luck with Walmart batteries than I did; in one year, same car, 1st one leaked, 2nd one had a bad cell, 3rd one finally OK and at that they were warning me that they wouldn't warranty it...as though the previous 2 were my fault. There was nothing wrong with that car's electrical system.
Re: batterys Bosch or interstate [Re: btomasko] #2497477
05/18/18 10:54 AM
05/18/18 10:54 AM
USA
3
360view Offline
360view  Offline
3
USA
Re: batterys Bosch or interstate [Re: 360view] #2497481
05/18/18 11:08 AM
05/18/18 11:08 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
On my regular drivers,two cars,one SUV,truck and JD tractor I've have been using NAPA Legend,all have given exceptional service.
Re: batterys Bosch or interstate [Re: btomasko] #2497513
05/18/18 12:33 PM
05/18/18 12:33 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
I will check when I get home but my 1995 CTD has 2 batteries that are 10 years old and still work.
My 2001 has 2 Napa batteries that are 4 years old. Still good.
Napa batteries are/were made by Deka. I lived about 1 hour from the Deka plant years ago. Whenever I needed a battery I would drive up and buy direct. Great batteries.
I have also had good luck with Optima batteries both red and yellow top.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: batterys Bosch or interstate [Re: btomasko] #2497522
05/18/18 12:44 PM
05/18/18 12:44 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I use Carquest AGM batteries on several cars with good luck, but I also had a friend that managed the store so I got excellent prices on them. For my diesel I have had the best luck with the Walmart Exxxtreme batteries (their "upper end"). I just replaced a pair that was 10 years old and still doing OK but getting sluggish.
Re: batterys Bosch or interstate [Re: 360view] #2497556
05/18/18 02:37 PM
05/18/18 02:37 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Never put mismatched batteries in parallel. They won't have the same charge/discharge profile which will eventually damage both of them. Batteries in parallel should always be changed in matched sets even if only one is bad.
