Re: batterys Bosch or interstate
[Re: btomasko]
#2496361
05/15/18 11:32 AM
05/15/18 11:32 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
We sold Interstates at the shop.had maybe 1 or 2 in 15 years that were bad.We run Advance batterys now.Never a problem.I get them discounted because of the shop i worked at and my sons a manager there also.Rocky
Chrysler Firepower
[Re: btomasko]
#2496652
05/15/18 09:31 PM
05/15/18 09:31 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I'm a huge Interstate user but you might consider Deka Batteries. Most are USA made.
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#2496775
05/16/18 10:18 AM
05/16/18 10:18 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I'm a huge Interstate user but you might consider Deka Batteries. Most are USA made. https://www.lowes.com/pd/Deka-12-Volt-81...ByABEgKNL_D_BwELowes Lumber seems to be a nationwide Deka seller. Is there a less expense seller of Deka? Marine versus Automotive? If you have room under the hood is a Marine rated Deka battery of adequate CCA likely to last longer in the road vibration environment of automotive service than the generally cheaper auto service rated batteries? I wish that a 1000 owner group of Cummins Ram owners with dual batteries under the hood would volunteer to do a long term test with both a marine and automotive rated battery in parallel service.
[Re: 360view]
#2497189
05/17/18 01:44 PM
05/17/18 01:44 PM
dogdays
Bosch and Interstate are both Johnson Controls batteries.
IMHO it is more important to get the latest manufactured battery.
360View, you can follow this link: https://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
Auto starting batteries are designed to deliver short jolts of max power. Deep Cycle batteries have less instantaneous current available but can be deeply discharged many more times without damage. Marine batteries need to be able to withstand periods of time without being recharged, like when the boat is sitting and you've got the lights and TV on, or running the refrigerator. Different designs for different uses.
R.
[Re: btomasko]
#2497263
05/17/18 05:00 PM
05/17/18 05:00 PM
Posts: 8,162 USA
360view
USA
The Wiki is pretty good on historical background. This article in the footnotes is interesting as it describes special test batteries in clear glass cases and experiments with whether Pulse Chargers and Cadnium Sulfate additives can do much beyond recovering about 30% of as new capacity. http://www.batteryvitamin.net/sulfation_remedies_demystified
[Re: btomasko]
#2497275
05/17/18 05:39 PM
05/17/18 05:39 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I have a pair of Interstate batteries in my Dodge truck that I bought in November 2012. They were bought "new" from the Interstate dealer during a special they had on new old stock batteries. Batteries that had sat on the shelf too long and were being sold a really low discount prices. If they died tomorrow I wouldn't be surprised, but they've lasted a lot longer than I expected them to. Think I paid about $90 for BOTH of them.
[Re: topside]
#2497376
05/17/18 10:51 PM
05/17/18 10:51 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Put a Deka in my car 10 years ago with only summer use and it's still going strong. I think I may just buy another one this year Now that I was bragging about it I better change it Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: btomasko]
#2497379
05/17/18 10:59 PM
05/17/18 10:59 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I own a 2006 Ram 3500 CTD 4 Whd that has both the original batteries in it, they acted weak last winter when trying to start it without the block heater hooked up so I went to the local Wal Mart and bought two new Duracell, maybe Everlast, which ever ones Walmart sells, replacement batteries. I plugged the heater in and those batteries are still in the truck now starting it okay. My message is try to find out who makes those Dodge CTD OEM batteries and buy them The OEM batteries in my old 1998 Ram 2500 1/2 CTD truck lasted 11 yrs also before one went bad, the other one lasted 9 months longer
[Re: btomasko]
#2497477
05/18/18 10:54 AM
05/18/18 10:54 AM
Posts: 8,162 USA
360view
USA
[Re: btomasko]
#2497513
05/18/18 12:33 PM
05/18/18 12:33 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
I will check when I get home but my 1995 CTD has 2 batteries that are 10 years old and still work.
My 2001 has 2 Napa batteries that are 4 years old. Still good.
Napa batteries are/were made by Deka. I lived about 1 hour from the Deka plant years ago. Whenever I needed a battery I would drive up and buy direct. Great batteries.
I have also had good luck with Optima batteries both red and yellow top.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
[Re: 360view]
#2497556
05/18/18 02:37 PM
05/18/18 02:37 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
I wish that a 1000 owner group of Cummins Ram owners with dual batteries under the hood would volunteer to do a long term test with both a marine and automotive rated battery Never put mismatched batteries in parallel. They won't have the same charge/discharge profile which will eventually damage both of them. Batteries in parallel should always be changed in matched sets even if only one is bad.
