1957 Coronet rear brakes #2487092
04/24/18 01:58 AM
04/24/18 01:58 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Got an issue with the rear brakes on the '57 that I'm working on and can't find a definitive answer. Were the drums swaged to the hubs? I've got one that looks like it used to be swaged, but is not and is not flat in the hub area, either. Seems like it's helping to cause a bind on that side as the drum does not appear to be centered.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487105
04/24/18 02:46 AM
04/24/18 02:46 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
They were originally swedged. When they get replaced then they no longer are attached and they will come off the hub.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487110
04/24/18 03:28 AM
04/24/18 03:28 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
These weren't cut off properly and the drum is warped in the wheel stud area. Replacements appear difficult to find. I guess I could try to straighten it...
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487145
04/24/18 09:34 AM
04/24/18 09:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dealt with this a lot because people have no idea about mostly removing the assembley.The drums when replaced were swedged back on with new studs.We used to have the tools at the shop years ago.I had a 61 polara that a so called mechanic puled the drums off with a jaw puller.So bad the pedal would pound up and down when you braked.Found a set of drums from a 60 that fit in a yard.Many have no idea that there is a special puer for them.Still have mine even though i dont have any early cars anymore.Rocky
Chrysler Firepower
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487615
04/25/18 01:23 AM
04/25/18 01:23 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I may have a lead on drums, but I measured the axle and the dimensions look nearly identical to an F-body. I'll get some better measurements tomorrow, but this may be the best way to go. Or, I'll send to owner to the local gear shop for a fresh built rear.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487777
04/25/18 01:51 PM
04/25/18 01:51 PM
moparx Offline
moparx  Offline
make sure to check the trueness of the hub flange to drum mating surface. it's very possible the flange was bent when the drum was removed improperly. seen this many times over the years when studs were replaced without removing the stud swedge on those keyed axle flange/drum assemblies.
beer
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487885
04/25/18 06:14 PM
04/25/18 06:14 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
That's exactly what happened. I have no way to measure the roundness of the braking surface, but it does bind in one place indicating that I can't get the drum centered.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2487906
04/25/18 07:08 PM
04/25/18 07:08 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
What years were these brakes used? Do the early 60's axles require the same service procedure?
Re: 1957 Coronet rear brakes [Re: QuickDodge] #2487944
04/25/18 08:32 PM
04/25/18 08:32 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yes, through 1964, I believe.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488043
04/26/18 12:29 AM
04/26/18 12:29 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1964 and older.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488125
04/26/18 09:32 AM
04/26/18 09:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes 64 and earlier.Ive seen so called mechanics even back in the day that didnt have a clue as to how they come off.I guess many never saw a Chiltons or service manual.One reason why when we had the 57 and 62 I bought the correct puller.Rocky
Chrysler Firepower
Re: 1957 Coronet rear brakes [Re: therocks] #2488179
04/26/18 11:40 AM
04/26/18 11:40 AM
moparx Offline
moparx  Offline
i've had my puller for close to 50 years, acquiring it at an auction of a garage that was going out of business. it has seen a ton of use, and i can't even remember the brand, although it is a top drawer puller. i used it last probably 15 or 20yrs ago, but it don't eat much, and lives in the bottom drawer, so it will stay around 'till i'm gone, and the "next guy" can worry about it then.
beer
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488379
04/26/18 05:55 PM
04/26/18 05:55 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I borrowed the puller from a friend of mine. The last time I had a need for one was in 1978 (a friend's dad used his on my '66 Dart GT when I had a front wheel bearing come apart - the inner race would not come off the spindle without the puller) so I figured that I really didn't need to own one.
I'm heading out tomorrow to the local Pick N Pull to see if the 1980 Volare still has the rear in it. The '57 rear is already out.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488387
04/26/18 06:12 PM
04/26/18 06:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
FWIW, the '65-'69 C-body rear end is a virtual drop-in for the '57-'61 FL cars. I just installed one in my '57 Dodge wagon, the pads are 1/2" different in spacing but the spring bushings will flex enough so that the difference isn't noticed.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488508
04/27/18 12:07 AM
04/27/18 12:07 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yeah, those are harder to find anymore. If the F-body doesn't measure properly I'll stop by one of the local yard that has a lot of rears sitting on racks.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488510
04/27/18 12:14 AM
04/27/18 12:14 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I just looked up the measurements. I didn't have an easy time measuring the other day, but I got better measurements now that the rear is out of the car. Looks like the F-body is too short. I'll take my chances at Turner's.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488558
04/27/18 02:46 AM
04/27/18 02:46 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Kanter lists them as part #04012B BD 2920.
It's Swifty! Swifty, you toad sucker!
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488611
04/27/18 10:58 AM
04/27/18 10:58 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
For the future. My 67 Jeep had swedged drums. Bought a 11/16" hole saw. Used it without the drill pilot to cut the swedge. Drum slid right off. Could have drilled new smaller stud holes. But since the drum pilots on the axle center and the wheel clamps it, no issue so far.
Doug
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2488865
04/27/18 11:11 PM
04/27/18 11:11 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yeah, these do not center the drum on the hub, only on the studs.
I think I already know the answer, but I am assuming that the housing ends are not the same as the later axle housings?
I found nothing out there today that would be a clean swap.
Re: 1957 Coronet rear brakes [Re: Jim_Lusk] #2489228
04/28/18 09:29 PM
04/28/18 09:29 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
The bearings and housing ends changed in '65.
Found that out while narrowing a rear axle for my '73 Dart some time back.
