Re: 1957 Coronet rear brakes
[Re: Jim_Lusk]
#2487145
04/24/18 09:34 AM
04/24/18 09:34 AM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
Dealt with this a lot because people have no idea about mostly removing the assembley.The drums when replaced were swedged back on with new studs.We used to have the tools at the shop years ago.I had a 61 polara that a so called mechanic puled the drums off with a jaw puller.So bad the pedal would pound up and down when you braked.Found a set of drums from a 60 that fit in a yard.Many have no idea that there is a special puer for them.Still have mine even though i dont have any early cars anymore.Rocky
Chrysler Firepower
[Re: QuickDodge]
#2487944
04/25/18 08:32 PM
04/25/18 08:32 PM
Posts: 18,677 Fresno, CA
Jim_Lusk
Fresno, CA
What years were these brakes used? Do the early 60's axles require the same service procedure? Yes, through 1964, I believe.
[Re: Jim_Lusk]
#2488125
04/26/18 09:32 AM
04/26/18 09:32 AM
therocks
Niles , Ohio
Yes 64 and earlier.Ive seen so called mechanics even back in the day that didnt have a clue as to how they come off.I guess many never saw a Chiltons or service manual.One reason why when we had the 57 and 62 I bought the correct puller.Rocky
Chrysler Firepower
[Re: Jim_Lusk]
#2488387
04/26/18 06:12 PM
04/26/18 06:12 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
FWIW, the '65-'69 C-body rear end is a virtual drop-in for the '57-'61 FL cars. I just installed one in my '57 Dodge wagon, the pads are 1/2" different in spacing but the spring bushings will flex enough so that the difference isn't noticed.
[Re: Jim_Lusk]
#2488558
04/27/18 02:46 AM
04/27/18 02:46 AM
Posts: 905 SD
zrxkawboy
SD
Kanter lists them as part #04012B BD 2920.
It's Swifty! Swifty, you toad sucker!
