904 Tranny Question #248691
03/09/09 05:40 PM
03/09/09 05:40 PM
Western Michigan
68Fastback Offline OP
Western Michigan
When I manually try to shift from first to second it feels like the trans is not shifting, I have to slow down shift into drive and it will work ok. It will kickdown fine in drive, the fluid looks ok, I tried less throttle pressure but still does it. Any ideas or suggestions and I am sorry if I explained this wacky.
Re: 904 Tranny Question [Re: 68Fastback] #248692
03/09/09 06:33 PM
03/09/09 06:33 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
maybe the valve body is nogood i would put a full manuel one i have one in both of my cars they work great
Re: 904 Tranny Question [Re: 68Fastback] #248693
03/09/09 10:00 PM
03/09/09 10:00 PM
Western Michigan
Western Michigan
Anyone ?
Re: 904 Tranny Question [Re: 68Fastback] #248694
03/10/09 03:50 PM
03/10/09 03:50 PM
Wyoming Michigan
The Beekeeper Offline
Wyoming Michigan
Drop pan, check band adjustments and make sure band pistons are seated in bores properly, if pan has excessive debris it may be time for a freshening...............Good luck.. ........Tom
Re: 904 Tranny Question [Re: The Beekeeper] #248695
03/10/09 05:07 PM
03/10/09 05:07 PM
scratchnfotraction Offline
drop pan,inspect/clean,adjust bands,adjust throttle pressure valve rod/linkage,test drive
could just need some adjusting
when I get the "no 2nd" thing,I do a band adjustment and use the test drive to look for another tranny
most times I get 2nd back and it holds for a while,I have done some jy trannys up to 3-4 adjustments before they give up
good luck
Re: 904 Tranny Question [Re: scratchnfotraction] #248696
03/10/09 07:25 PM
03/10/09 07:25 PM
Western Michigan
Western Michigan
To me it feels like it is not releasing when manually shifting first to second. The fluid looks red with no smell, and shifts great driving around normally, even with less throttle presure adjustment. Only acts up when you get on it and manually shift, tranny has less than 2k miles.
Re: 904 Tranny Question [Re: 68Fastback] #248697
03/10/09 09:47 PM
03/10/09 09:47 PM
BA, OK
O
orangedustya Offline
O
BA, OK
Mine did that on my dart , adjusted the band and it did not help. Ended up pulling the valve body to get to the band apply servo, changed the steel seal on it, put it back together and everything was fine.
Brad
Re: 904 Tranny Question/Update pic [Re: orangedustya] #248698
06/10/09 11:13 PM
06/10/09 11:13 PM
Western Michigan
Western Michigan
Well this is what I found.
Re: 904 Tranny Question/Update pic [Re: 68Fastback] #248699
06/11/09 03:51 PM
06/11/09 03:51 PM
Western Michigan
Western Michigan
Anyone have a idea on what might of caused this.
Re: 904 Tranny Question/Update pic [Re: 68Fastback] #248700
06/11/09 03:57 PM
06/11/09 03:57 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
I had the same thing happen, but dont know why.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: 904 Tranny Question/Update pic [Re: 68Fastback] #248701
06/11/09 04:08 PM
06/11/09 04:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think the cracked drum is coincidental to your shifting problem.
When a trans won't shift 1-2 at WOT the problem is usually too much throttle pressure, the governor wants more rpm than the engine is capable of.
Re: 904 Tranny Question/Update pic [Re: John_Kunkel] #248702
06/11/09 06:29 PM
06/11/09 06:29 PM
Western Michigan
Western Michigan
John I think I might have said before the shifting issue would happen no matter what throttle pressure. It does drive and act so much better now but have not tried shifting manually yet.
Re: 904 Tranny Question/Update pic [Re: 68Fastback] #248703
06/12/09 03:03 PM
06/12/09 03:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In your original post you stated "I tried less throttle pressure but still does it".....in that case try even less.
