383 build need to use adjustable rockers #2486721
04/23/18 08:14 AM
04/23/18 08:14 AM
Woodbridge
Tommy The Chryco Offline OP
Woodbridge
But i want to keep the stock look. Any suggestions for what rockers i should purchase.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: 383 build need to use adjustable rockers [Re: Tommy The Chryco] #2486764
04/23/18 12:18 PM
04/23/18 12:18 PM
sweden
carter Offline
carter  Offline
sweden
Crane or Isky mek rocker fit under a stock valvecover.
Re: 383 build need to use adjustable rockers [Re: Tommy The Chryco] #2486837
04/23/18 02:36 PM
04/23/18 02:36 PM
Ductile iron rockers as already mentioned, you may need to dimple, bend or put holes in the baffles to clear them depending on which cam and lift scope
You can also double up a set of the thicker after market valve cover gaskets to clear them also, sometimes that works but not always scope shruggy
Re: 383 build need to use adjustable rockers [Re: Tommy The Chryco] #2486918
04/23/18 06:12 PM
04/23/18 06:12 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Isky iron adjustable rockers hit the baffles on my stock 1969 valve covers with a .525" solid lift cam. If your lift is significantly less, those rockers might not hit, but the if the same or higher, they will probably hit.
beer
Paul
'69 Super Bee 383 EFI Turbo
Re: 383 build need to use adjustable rockers [Re: Tommy The Chryco] #2486953
04/23/18 08:05 PM
04/23/18 08:05 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The Crane adjustibles are actually thinner at the valve tip than the Iskys. Mine fit fine with the Mopar .557
Re: 383 build need to use adjustable rockers [Re: R/T1968R/T] #2486956
04/23/18 08:15 PM
04/23/18 08:15 PM
It is usually the adjuster end tip that hits the baffles on stock covers, if you use a shorter pushrod you can help those clearances a little as long as you don't get the adjuster to far out work scope
I have massaged whistling more than one stock baffle, I have also removed them which I shouldn't have tsk realcrazy
Re: 383 build need to use adjustable rockers [Re: Cab_Burge] #2486991
04/23/18 10:19 PM
04/23/18 10:19 PM
IN
ahy Offline
ahy  Offline
IN
I used Comp "pro magnum" cast alloy steel rockers. Pushrods were set so about 1 1/2 threads showed... as desired. Geometry was good. I did use MP cast Al black valve covers. I do not know if these have more or less clearance vs stock covers.
Re: 383 build need to use adjustable rockers [Re: Tommy The Chryco] #2487043
04/23/18 11:38 PM
04/23/18 11:38 PM
Chicago
PurpleBeeper Online content
PurpleBeeper  Online Content
Chicago
This is puzzling me right now. My current motor has Isky rockers & with a 292/509 Mopar purple shaft cam I hit the baffles. I removed the baffles and I'm sucking oil through the PCV valve. I added a slightly modified compressor air/water separator, but I really need to get baffles back in the valve covers.
The double gasket idea sounds like a really good one.
I've got some "truck" big block valve covers I could use, but I'm not sure if the baffles are any higher up even though valve covers are slightly taller.
I have no idea which adjustables are "low profile". I will be watching this thread closely.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 383 build need to use adjustable rockers [Re: PurpleBeeper] #2487052
04/24/18 12:02 AM
04/24/18 12:02 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've used Crane iron, Isky iron, Crane alum., and Comp Magnums with .500 to .630 lift with stock valve covers. Slight baffle tweaking, but never removed any.
