What Pistons to use for a 440 Build #2481811
04/12/18 08:26 PM
04/12/18 08:26 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
So I am thinking of building a 440 engine to run mostly at the track. Probably a on the milder side build. Here is what I have so far. 440 block, stock steel crank and rods, indy 440 port 2.19 1.81 heads, M1 intake and not sure on cam, but thinking .590 solid. Will use ARP main bearing, rods and head studs. Not thinking of much more than 6K rpm. Using a 727 with 4K stall and 4.10 gears. I was thinking of the forged six pack pistons but people say they are too heavy.. what do you think? Thanks.
RS23L7 4-Speed
Re: What Pistons to use for a 440 Build [Re: Mopar_Mike] #2481819
04/12/18 08:36 PM
04/12/18 08:36 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Call ICON and get what you need. I would run a forged, light as possible. Get a thin ring pack 1/16-1/16-3/16 max I like .043-.043-3.0mm
Re: What Pistons to use for a 440 Build [Re: Mopar_Mike] #2481856
04/12/18 10:20 PM
04/12/18 10:20 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I agree with the thinner ring pack, more power for almost no cost.
Checked Summit for 0.030" over, 1/16" rings, 1.094" pin, 3.75" stroke and these are showing as shelf stocked pistons, sorted by compression height.
ICON 968-30 - 2.067" compression height - $626.97
ROSS 82008 - 2.065" CH - $689.97
SRP 213455-8 - 2.062" CH - $561.20
JE 213466-8 - 2.058" CH - $746.93
Wiseco PTS531A3 - 2.050" CH - $486.00
Re: What Pistons to use for a 440 Build [Re: Mopar_Mike] #2481916
04/12/18 11:54 PM
04/12/18 11:54 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I used srp in the past had good results with them ... times are in my signature used them for 4.5 years
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: What Pistons to use for a 440 Build [Re: 67mprfan] #2481978
04/13/18 02:05 AM
04/13/18 02:05 AM
I had a SRP forged 340 stroker piston break, fracture, the wrist pin boss broke off of one side of their piston at 2000 RPM with less than three minutes of running while breaking in the new cam down It tore up that rod, the other piston across from it along with the other rod and broke the cylinder wall on the bad piston side and crankshaft throw puke
I sent them both pistons and rods and they wouldn't do any thing about it runaway puke
I contacted Scat and SRP as I wasn't sure what broke first, the rod and wrist pin where laying beside each other in the oil pan along with the broken piston parts work Scat was willing to work with me on it but after looking at it thoroughly the piston failed first shruggy
I'm going to file a complaint with the Better Business Bureau and if that doesn't get any good results I will file with the State of CA consumer board on defective auto parts work
Re: What Pistons to use for a 440 Build [Re: Mopar_Mike] #2482011
04/13/18 08:30 AM
04/13/18 08:30 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
In my 440 i used SRP , made good power for 10 years daily plus bracket racing , only ever got faster
Got 440 source in new motor , i think they are icon
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What Pistons to use for a 440 Build [Re: Mopar_Mike] #2482030
04/13/18 09:56 AM
04/13/18 09:56 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Diamond Pistons. Fair prices and very flexible with modifications...
