I had a SRP forged 340 stroker piston break, fracture, the wrist pin boss broke off of one side of their piston at 2000 RPM with less than three minutes of running while breaking in the new cam
It tore up that rod, the other piston across from it along with the other rod and broke the cylinder wall on the bad piston side and crankshaft throw
I sent them both pistons and rods and they wouldn't do any thing about it
I contacted Scat and SRP as I wasn't sure what broke first, the rod and wrist pin where laying beside each other in the oil pan along with the broken piston parts
Scat was willing to work with me on it but after looking at it thoroughly the piston failed first
I'm going to file a complaint with the Better Business Bureau and if that doesn't get any good results I will file with the State of CA consumer board on defective auto parts
