Need help 4 speed reverse lamp switch #2479908
04/09/18 12:11 PM
04/09/18 12:11 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Working on a 74 Challenger that had been converted from Auto to 4 speed.
Looking for a two prong reverse lamp switch that goes into the trans.
The one in the trans has power going in but no power coming out.
All the wiring has been converted correctly including the reverse light mounted in the dash and the clutch starter switch.
I had no luck sourcing a new reverse light switch.
Can anybody at least have a part number I can interchange ??
Thanks in advance.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2479956
04/09/18 01:28 PM
04/09/18 01:28 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
help LOL
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2479961
04/09/18 01:39 PM
04/09/18 01:39 PM
New York
rarefish Offline
rarefish  Offline
New York
They are available through most part stores or Rock Auto, but they are all Chinese made ones that turn out to be pretty lousy. The factory original in my 4 speed crapped out. The switch was stuck in the close position so the reverse lamps were on all the time. The first replacement one I bought leaked shortly after it was install so I had to return it for another.
The pictures show the factory one on the left and on the right is a crappy one that is sold today.
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480030
04/09/18 03:27 PM
04/09/18 03:27 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks..so I may have to search for a good used one,eh?
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480139
04/09/18 07:23 PM
04/09/18 07:23 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
I searched Rock Auto but not coming up
Anbody have a part # I can use or reference??
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480147
04/09/18 07:42 PM
04/09/18 07:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Factory P/N is 3488270
NAPA is MPE NS6571SB
Re: Need help 4 speed reverse lamp switch [Re: John_Kunkel] #2480155
04/09/18 07:57 PM
04/09/18 07:57 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480228
04/09/18 10:45 PM
04/09/18 10:45 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480255
04/09/18 11:37 PM
04/09/18 11:37 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
up Thanks everybody!! beer
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480368
04/10/18 09:29 AM
04/10/18 09:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Didnt Joe Six Pack a member have some NOS ones?I know he has a ton of old stuff.My 65s works perfect knock on wood.Rocky
Chrysler Firepower
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480371
04/10/18 09:39 AM
04/10/18 09:39 AM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
got one ordered.Thank again everybody!!
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480389
04/10/18 10:46 AM
04/10/18 10:46 AM
New York
rarefish Offline
rarefish  Offline
New York
I forgot to tell you, but for some reason when looking on Rock Auto's web site. You have to search a 1970 model or later. The two prong switch used in the manual transmission does not show up on any of the pre 70 listings.
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480443
04/10/18 12:44 PM
04/10/18 12:44 PM
pa.
dan9 Offline
dan9  Offline
pa.
Maybe 74 is different but if I remember correctly that switch just completed ground in the 70 models. Did you check for continuity between the 2 posts while in reverse with no wires connected?
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480506
04/10/18 02:53 PM
04/10/18 02:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The switch is hot one side and powers the lights on the other.Only reason for a ground circuit was for N start as far as I know.rocky
Chrysler Firepower
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480549
04/10/18 04:17 PM
04/10/18 04:17 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
As dan9 mentioned, check across the 2 terminals of the switch, in reverse, it should be a dead short. Mine was intermittent at times, new switch, worked like a charm.
Re: Need help 4 speed reverse lamp switch [Re: Pntastar69] #2480571
04/10/18 04:41 PM
04/10/18 04:41 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Yup. switch no good.
Thanks!!
Re: Need help 4 speed reverse lamp switch [Re: 68Cbarge] #2480628
04/10/18 06:18 PM
04/10/18 06:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure its gettin cotacted inside.IIRC there were some gaskets that were thick and would not let the ball detent all the way in.Simple to check remove press ball in and see if it is a closed circuit.Rocky
Chrysler Firepower
Re: Need help 4 speed reverse lamp switch [Re: therocks] #2480630
04/10/18 06:21 PM
04/10/18 06:21 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
