Need help 4 speed reverse lamp switch
#2479908
04/09/18 12:11 PM
04/09/18 12:11 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Working on a 74 Challenger that had been converted from Auto to 4 speed.
Looking for a two prong reverse lamp switch that goes into the trans. The one in the trans has power going in but no power coming out. All the wiring has been converted correctly including the reverse light mounted in the dash and the clutch starter switch.
I had no luck sourcing a new reverse light switch. Can anybody at least have a part number I can interchange ?? Thanks in advance.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
Re: Need help 4 speed reverse lamp switch
[Re: 68Cbarge]
#2480030
04/09/18 03:27 PM
04/09/18 03:27 PM
68Cbarge
Canuckville
Thanks..so I may have to search for a good used one,eh?
[Re: 68Cbarge]
#2480139
04/09/18 07:23 PM
04/09/18 07:23 PM
68Cbarge
Canuckville
I searched Rock Auto but not coming up Anbody have a part # I can use or reference??
[Re: 68Cbarge]
#2480147
04/09/18 07:42 PM
04/09/18 07:42 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Factory P/N is 3488270
NAPA is MPE NS6571SB
[Re: 68Cbarge]
#2480368
04/10/18 09:29 AM
04/10/18 09:29 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Didnt Joe Six Pack a member have some NOS ones?I know he has a ton of old stuff.My 65s works perfect knock on wood.Rocky
Chrysler Firepower
[Re: 68Cbarge]
#2480371
04/10/18 09:39 AM
04/10/18 09:39 AM
68Cbarge
Canuckville
got one ordered.Thank again everybody!!
[Re: 68Cbarge]
#2480389
04/10/18 10:46 AM
04/10/18 10:46 AM
Posts: 2,252 New York
rarefish
New York
I searched Rock Auto but not coming up Anbody have a part # I can use or reference?? I forgot to tell you, but for some reason when looking on Rock Auto's web site. You have to search a 1970 model or later. The two prong switch used in the manual transmission does not show up on any of the pre 70 listings.
[Re: 68Cbarge]
#2480506
04/10/18 02:53 PM
04/10/18 02:53 PM
therocks
Niles , Ohio
The switch is hot one side and powers the lights on the other.Only reason for a ground circuit was for N start as far as I know.rocky
Chrysler Firepower
[Re: Pntastar69]
#2480571
04/10/18 04:41 PM
04/10/18 04:41 PM
68Cbarge
Canuckville
As dan9 mentioned, check across the 2 terminals of the switch, in reverse, it should be a dead short. Mine was intermittent at times, new switch, worked like a charm. Yup. switch no good. Thanks!!
[Re: 68Cbarge]
#2480628
04/10/18 06:18 PM
04/10/18 06:18 PM
therocks
Niles , Ohio
Make sure its gettin cotacted inside.IIRC there were some gaskets that were thick and would not let the ball detent all the way in.Simple to check remove press ball in and see if it is a closed circuit.Rocky
Chrysler Firepower
