Re: Drag radial vs QTP pinion angle
[Re: mopar dave]
#2479363
04/08/18 01:02 PM
04/08/18 01:02 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
In my opinion you want to try to get the drive shaft as close to straight as possible without going past straight under acceleration.. my old application was about right with 3*.. now I run 7*.. I bounce between bias and radials all the time.. and never change pinion angle.. maybe you can get a camera down there and watch what's going on and get an accurate set up for your combination
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: mopar dave]
#2479379
04/08/18 01:17 PM
04/08/18 01:17 PM
WHITEDART
bean town ....Ca
ok, i may be good where its at then. I have 1* on the shaft and 1* on the pinion. I would think that it would be safe place to start.. keep us posted on your e t improvements with the radial
[Re: WHITEDART]
#2479502
04/08/18 04:39 PM
04/08/18 04:39 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Had radial for years before the QTP. QTP are quicker. Didn't have the correct chassis set up for the radial at the time. The QTP was quicker but the radial was faster.
[Re: Thumperdart]
#2479990
04/09/18 02:35 PM
04/09/18 02:35 PM
WHITEDART
bean town ....Ca
I'd be a bit concerned at 2* myself as that's in the ladder bar/4-link zone w/a lot less wrap up......5 would be a good happy medium imo........ .. okay I'll bite ...why would two degrees on a car that's 99% Street driven concern you.. I'm just curious. And what would be the consequences of running it like this
[Re: WHITEDART]
#2480057
04/09/18 04:13 PM
04/09/18 04:13 PM
Thumperdart
State of confusion
I'd be a bit concerned at 2* myself as that's in the ladder bar/4-link zone w/a lot less wrap up......5 would be a good happy medium imo........ .. okay I'll bite ...why would two degrees on a car that's 99% Street driven concern you.. I'm just curious. And what would be the consequences of running it like this I ran too little pinion angle years ago and it wrapped up pretty good and felt a horrible vibration on acceleration because like you stated, "You'd like the DS to be near or zero under full load" but I can't even drive right so don't listen to my azz...........
[Re: WHITEDART]
#2480391
04/10/18 10:55 AM
04/10/18 10:55 AM
WHITEDART
bean town ....Ca
I tried but I guess you did not like it..keep fishing tell you catch the answer you like
[Re: WHITEDART]
#2480407
04/10/18 11:47 AM
04/10/18 11:47 AM
mopar dave
Mt Morris Michigan
I understood the first time. 3* is the target. Where did you take your measures to arrive at 3*? Thank you
