Drag radial vs QTP pinion angle #2479355
04/08/18 12:54 PM
04/08/18 12:54 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I know this has been beat to death, but whats the latest on pinion angle needed for Drag radial vs the QTP? I'm buying new tires to replace the QTP's and going back to a drag radial for 99% street driving. My current pinion angle is 2* down. Thanks
Re: Drag radial vs QTP pinion angle [Re: mopar dave] #2479360
04/08/18 12:58 PM
04/08/18 12:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
What rear suspension?
Re: Drag radial vs QTP pinion angle [Re: ProSport] #2479362
04/08/18 01:01 PM
04/08/18 01:01 PM
Mt Morris Michigan
Mt Morris Michigan
Dana with cal tracs. Gonna change out the front springs for longer to get the tire centered and will be a good time to set correct pinion angle for the Radials.
Re: Drag radial vs QTP pinion angle [Re: mopar dave] #2479363
04/08/18 01:02 PM
04/08/18 01:02 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
In my opinion you want to try to get the drive shaft as close to straight as possible without going past straight under acceleration.. my old application was about right with 3*.. now I run 7*.. I bounce between bias and radials all the time.. and never change pinion angle.. maybe you can get a camera down there and watch what's going on and get an accurate set up for your combination
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2479370
04/08/18 01:11 PM
04/08/18 01:11 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i may be good where its at then. I have 1* on the shaft and 1* on the pinion.
Re: Drag radial vs QTP pinion angle [Re: mopar dave] #2479379
04/08/18 01:17 PM
04/08/18 01:17 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would think that it would be safe place to start.. keep us posted on your e t improvements with the radial
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2479502
04/08/18 04:39 PM
04/08/18 04:39 PM
Mt Morris Michigan
Mt Morris Michigan
Had radial for years before the QTP. QTP are quicker. Didn't have the correct chassis set up for the radial at the time. The QTP was quicker but the radial was faster.
Re: Drag radial vs QTP pinion angle [Re: mopar dave] #2479551
04/08/18 06:27 PM
04/08/18 06:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'd be a bit concerned at 2* myself as that's in the ladder bar/4-link zone w/a lot less wrap up......5 would be a good happy medium imo........ beer
Re: Drag radial vs QTP pinion angle [Re: Thumperdart] #2479562
04/08/18 06:41 PM
04/08/18 06:41 PM
Mt Morris Michigan
Mt Morris Michigan
Ok Dom. I'll make note of that. I wasn't sure how much movement or wrap up there was down there compared to a ladder.
Re: Drag radial vs QTP pinion angle [Re: mopar dave] #2479566
04/08/18 07:04 PM
04/08/18 07:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Calvert recommends measuring the angle of the transmission and the angle of the pinion. The driveshaft angle is not measured in their method. IIRC my tail shaft is down 1.7° and the pinion is yoke down 1.8°, 3.5° total. I think Calvert recommends 2-4°.
Re: Drag radial vs QTP pinion angle [Re: justinp61] #2479572
04/08/18 07:13 PM
04/08/18 07:13 PM
Mt Morris Michigan
Mt Morris Michigan
Its been a few years since i talked to calverts but they recommended 3* pinion angle back then. I will have to remeasure the tailshaft angle which was 2* with the small block if i remember correct. I now have a BB with an engine plate, so remeasuring tail shaft angle i will for sure.
Re: Drag radial vs QTP pinion angle [Re: Thumperdart] #2479990
04/09/18 02:35 PM
04/09/18 02:35 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
.. okay I'll bite ...why would two degrees on a car that's 99% Street driven concern you.. I'm just curious. And what would be the consequences of running it like this
Re: Drag radial vs QTP pinion angle [Re: mopar dave] #2480056
04/09/18 04:08 PM
04/09/18 04:08 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I would assume a drag radial car running Cal Tracks has a fair amount of seperation and housing rotation. Thus more pinion angle required to keep the pinion C/L from rotating past the driveshaft C/L under acceleration.
Doug
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2480057
04/09/18 04:13 PM
04/09/18 04:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran too little pinion angle years ago and it wrapped up pretty good and felt a horrible vibration on acceleration because like you stated, "You'd like the DS to be near or zero under full load" but I can't even drive right so don't listen to my azz........... realcrazy
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2480130
04/09/18 07:05 PM
04/09/18 07:05 PM
Mt Morris Michigan
Mt Morris Michigan
Because it will see the track now and then. So if it wont hook, its a wasted day at the track. 99% street.
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2480381
04/10/18 10:09 AM
04/10/18 10:09 AM
Mt Morris Michigan
Mt Morris Michigan
Looks like no one has found drag radials needing a different pinion angle than a bias tire. Just thought i would check before getting this apart and get the best angle while i'm in there.
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2480391
04/10/18 10:55 AM
04/10/18 10:55 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I tried but I guess you did not like it..keep fishing tell you catch the answer you like
Re: Drag radial vs QTP pinion angle [Re: WHITEDART] #2480407
04/10/18 11:47 AM
04/10/18 11:47 AM
Mt Morris Michigan
Mt Morris Michigan
I understood the first time. 3* is the target. Where did you take your measures to arrive at 3*? Thank you
