Fitting for in line trans oil temp
#2475248
04/01/18 12:03 PM
04/01/18 12:03 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Like the SW 82410-72 mechanical bulb sensor.I want to splice it in line 3/8" on the return side
Re: Fitting for in line trans oil temp
[Re: Clanton]
#2475294
04/01/18 12:43 PM
04/01/18 12:43 PM
Clanton
northern,Ohio,USA
Looks like the barb/pushloc fitting is a 3/8" npt and the adaptor is also to go into a tee for them all.[or a 1/4"npt?]
[Re: Clanton]
#2475400
04/01/18 03:04 PM
04/01/18 03:04 PM
Clanton
northern,Ohio,USA
727 3/8 push loc hose with barb in/out.I went to 3/8 to make it easier to find plus the oil cooler is 3/8 push on in/out 25k gvw cooler 8 tube with a 400 cfm fan
[Re: Clanton]
#2475457
04/01/18 04:43 PM
04/01/18 04:43 PM
Clanton
northern,Ohio,USA
I got a tee at homedepot and it is a 1/4" I findout.
[Re: Clanton]
#2475473
04/01/18 05:06 PM
04/01/18 05:06 PM
Clanton
northern,Ohio,USA
I need a male center to bring the tip in in the tee. What do you think?
[Re: A39Coronet]
#2475568
04/01/18 08:26 PM
04/01/18 08:26 PM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Any reason you're pulling temps from the line vs. the pan? That is coming out of the converter, which is as hot as is going to get. If the fluid is getting hot enough to burn the oil that is the only place you can find out. However I would agree that the fluid temp in the pan is interesting and that would tell you the coolest the oil is at the time and if it is too hat and could damage transmission parts. I have done it both ways.
[Re: 340Cuda]
#2475574
04/01/18 08:32 PM
04/01/18 08:32 PM
Clanton
northern,Ohio,USA
Any reason you're pulling temps from the line vs. the pan? That is coming out of the converter, which is as hot as is going to get. If the fluid is getting hot enough to burn the oil that is the only place you can find out. However I would agree that the fluid temp in the pan is interesting and that would tell you the coolest the oil is at the time and if it is too hat and could damage transmission parts. I have done it both ways. Thank for the tip and agree
[Re: 340Cuda]
#2475578
04/01/18 08:34 PM
04/01/18 08:34 PM
Clanton
northern,Ohio,USA
Interesting manifold and would be ok with electric temp sensor looks like but the bulb on the mechanical would need an extension like I show or it would bottom out.
[Re: Clanton]
#2475581
04/01/18 08:37 PM
04/01/18 08:37 PM
340Cuda
Tulsa, Oklahoma
Interesting manifold and would be ok with electric temp sensor looks like I run mine with a mechanical gauge with the same type adapter typically used in the intake manifold for the water temperature gauge.
