Fitting for in line trans oil temp #2475248
04/01/18 12:03 PM
04/01/18 12:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Like the SW 82410-72 mechanical bulb sensor.I want to splice it in line 3/8" on the return side
Re: Fitting for in line trans oil temp [Re: Clanton] #2475253
04/01/18 12:10 PM
04/01/18 12:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My q is more on the main block that this all fits together in.
Re: Fitting for in line trans oil temp [Re: Clanton] #2475294
04/01/18 12:43 PM
04/01/18 12:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Looks like the barb/pushloc fitting is a 3/8" npt and the adaptor is also to go into a tee for them all.[or a 1/4"npt?]
Re: Fitting for in line trans oil temp [Re: Clanton] #2475359
04/01/18 01:49 PM
04/01/18 01:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What trans is this for.. a 727 is 5/16 trans
line but a 518 is 3/8
wave
Re: Fitting for in line trans oil temp [Re: Clanton] #2475400
04/01/18 03:04 PM
04/01/18 03:04 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
727 3/8 push loc hose with barb in/out.I went to 3/8 to make it easier to find plus the oil cooler is 3/8 push on in/out 25k gvw cooler 8 tube with a 400 cfm fan
Re: Fitting for in line trans oil temp [Re: Clanton] #2475457
04/01/18 04:43 PM
04/01/18 04:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got a tee at homedepot and it is a 1/4" I findout.
Re: Fitting for in line trans oil temp [Re: Clanton] #2475470
04/01/18 05:00 PM
04/01/18 05:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got an extension to back out the bulb and not restrict flow but hope it won't effect the reading 1" back from the direct flow.
Re: Fitting for in line trans oil temp [Re: Clanton] #2475473
04/01/18 05:06 PM
04/01/18 05:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I need a male center to bring the tip in in the tee.
What do you think?
Re: Fitting for in line trans oil temp [Re: Clanton] #2475549
04/01/18 08:01 PM
04/01/18 08:01 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have something similar to this and like it. They are available in different sizes.
https://www.summitracing.com/parts/atm-2286
Re: Fitting for in line trans oil temp [Re: Clanton] #2475561
04/01/18 08:15 PM
04/01/18 08:15 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Any reason you're pulling temps from the line vs. the pan?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Fitting for in line trans oil temp [Re: A39Coronet] #2475568
04/01/18 08:26 PM
04/01/18 08:26 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That is coming out of the converter, which is as hot as is going to get. If the fluid is getting hot enough to burn the oil that is the only place you can find out.
However I would agree that the fluid temp in the pan is interesting and that would tell you the coolest the oil is at the time and if it is too hat and could damage transmission parts.
I have done it both ways.
Re: Fitting for in line trans oil temp [Re: 340Cuda] #2475574
04/01/18 08:32 PM
04/01/18 08:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank for the tip and agree
Re: Fitting for in line trans oil temp [Re: 340Cuda] #2475578
04/01/18 08:34 PM
04/01/18 08:34 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Interesting manifold and would be ok with electric temp sensor looks like but the bulb on the mechanical would need an extension like I show or it would bottom out.
Re: Fitting for in line trans oil temp [Re: Clanton] #2475581
04/01/18 08:37 PM
04/01/18 08:37 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I run mine with a mechanical gauge with the same type adapter typically used in the intake manifold for the water temperature gauge.
Re: Fitting for in line trans oil temp [Re: Clanton] #2478424
04/06/18 06:03 PM
04/06/18 06:03 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I went with bigger Tee,update on parts list after the gauge came with a bigger adptor on the bulb and for more flow by it.
