Carb lines/ fuel rail/ regulator set up pics #2474525
03/30/18 07:50 PM
03/30/18 07:50 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I need to see how guys feed the carb today from the regulator to the bowls. I am struggling with how I’m gonna mount this stuff
eBay-cdwmotorsports
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2474593
03/30/18 10:26 PM
03/30/18 10:26 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Though many say to leave the regulator float mine is mounted solid. Mine is an odd combination with Eddy carbs. The regulator mounting could be used for anything. Carb plate is drilled and tapped 1/4-20. Stainless tube covers the threads.
Doug
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2474599
03/30/18 10:31 PM
03/30/18 10:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used an AED kit for a Holley/Quick Fuel regulator and it fits nice.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2474602
03/30/18 10:32 PM
03/30/18 10:32 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I mounted my regulator on the front of the intake manifold.
Re: Carb lines/ fuel rail/ regulator set up pics [Re: sgcuda] #2474678
03/31/18 12:40 AM
03/31/18 12:40 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I made a bracket that mounts off of my upper water pump bolts.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2474686
03/31/18 12:57 AM
03/31/18 12:57 AM
Martinsville, IN
Martinsville, IN
Thanks guys, those look like good options.
Good lord 6pkrtse, like NOS much?
eBay-cdwmotorsports
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2475899
04/02/18 10:30 AM
04/02/18 10:30 AM
an8sec70cuda Offline
I also made a bracket to hold a fuel log to the front of the manifold.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2476585
04/03/18 01:03 AM
04/03/18 01:03 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
For those who have mounted their regulators in front of the Intake are you not concerned with the fuel gettingnto hot ? Are you running regulators that return the excess fuel to the tank?
My simple Holley regulator is on the passenger inner fender.
I had planned to run a single Holley but switched to a tunnel ram and 450 holleys which have their fuel Inlet’s on the driver side. Drivers side is pretty busy with other stuff not sure I can relocate the regulator over there.
Re: Carb lines/ fuel rail/ regulator set up pics [Re: NTOLERANCE] #2476664
04/03/18 10:21 AM
04/03/18 10:21 AM
It's kinda hard to see, but my log has a -10 inlet on the passenger's side. The regulator on the driver's side end is the return, -8 back to the tank.
CHIP
Re: Carb lines/ fuel rail/ regulator set up pics [Re: NTOLERANCE] #2476736
04/03/18 01:13 PM
04/03/18 01:13 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
[quote=NTOLERANCE]For those who have mounted their regulators in front of the Intake are you not concerned with the fuel gettingnto hot ? Are you running regulators that return the excess fuel to the tank?
I expect that you pick up less heat running the fuel lines in from the front rather than over the top of a hot header.
Real Men shift for themselves
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2477235
04/04/18 04:34 AM
04/04/18 04:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just have my reg secured to the fenderwell with two screws and a rubber gasket under it. Works fine on my street car. Ron
Re: Carb lines/ fuel rail/ regulator set up pics [Re: cdwmotorsports] #2477417
04/04/18 03:23 PM
04/04/18 03:23 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Mine's a little different. -8 feed -10 return.with the regulator at the rear .
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
